Turbos and boost
RE: Turbos and boost
Could it be because all I have is a 3" down pipe off of the turbo?
If it was my car I'd check the guage first, and if that isn't the problem take the turbo down and make sure it spins free, then start replacing vacuum lines (not like they are expencive).If its none of the above you might have to invest in a new waste gate
ORIGINAL: turbo2.3stang
If it was the wastegate, then you would have an overboost problem since it's not letting any pressure to be by-passed. Check fora locked up turbo.
Even with the wastegate wide open, youll still make a few PSI.
Post more info! What do you mean no boost? While driving or while reving in your driveway? See that you are running a straight 3" down pipe this is a valid question. If you are reving in your drive you will never show boost unless you are power braking (no load + no boost)
Really need more info
jwog666
12-27-2021 08:09 PM
