svo a arms
svo a arms
new to the forums,i am building a mustang to dirt race with.i was wondering about using svo a arms in the front.1st question is how much wider are they than a stock one?i also know they are hard to find,and i assume you cant replace the ball joints. is there an alternative to using the svo arms and getting the same width,anyway i am trying to get the widest stance i can get,i was also wondering if the thunderbird axles are wider than the mustang in the 7.5 setup.
RE: svo a arms
I would not use the SVO A-arms. The ball joints cannot be replaced and they are typically hard to come by. The sn95 mustang A-arms are similar as well as the 87-88 turbo coupe A-arms.
I do believe that the 83-86 turbo coupe axles are longer than the mustangs. At least they were when we compared the two.
RE: svo a arms
That is irrelevant to the question asked. The axles is what he asked about with which the 83-86 axles will give a wider stance. It does not matter whether they came from a 7.5 or an 8.8. An 8.8 is not even needed on a 4 cylinder mustang until you get up to the insane power levels.
RE: svo a arms
ORIGINAL: 17racer
But then again that just might be me...
And yes the 8.8 rear differencial is bigger (wider)
turbo2.3, I don't mean to rag on you, but you should read his post a little more close[8D]
RE: svo a arms
The 8.8 rear end is not wider, it is the exact same width. I have had many rear ends taken out of cars, both 7.5 and 8.8. If the 8.8 was in fact wider, then the axles from the Mustang 5.0's and the 4 cylinder cars would not interchange...but they do. First thing we need to know is what year Thunderbird he is talking about. By comparison, the axles from an 86 turbo coupe were wider than the 7.5/8.8 mustang, 4 lug axles.
