New Features: Ford Mustang Knowledge Base
Go Back   MustangForums.com > Ford Mustang Tech > 4 Cylinder NA and Turbo > SVO Forum
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 05-10-2009, 02:17 PM   #1
escortgtx
Default motor differences
I've tried to find out if the 1979 SVO 2.3 motor/block is the same through 93. I got it yesterday and it still has the carb setup but I'd remove that right away. My big question is can this motor make power? I've been dealing with turbo 1.8DOHC making 350whp on stock internals so I'm hoping this motor can do better. Also I need a strong tranny and was told I could use a 5.0 T5 with the 2.3 bell housing(true?)
__________________
P Performance Video
escortgtx is offline   Reply With Quote
Old 06-26-2009, 09:24 PM   #2
MarioP3_XR4Ti
Send a message via Yahoo to MarioP3_XR4Ti
Wow this forum section doesn’t get much action does it?
Well the short answer is that the blocks are fairly similar over the years – with exceptions as turbochargers, fuel injection etc. were added. I suspect since you’ve a turbo motor block it should suffice for whatever you wish to do with it. The crank is the same from 1974 to 1991 as far as I can find on the ‘net. The big addition you’d need you should already have, an oil return boss for the turbo.
You can make as much power as you are willing to spend money on. However almost all the performance adders are going to be geared towards a EFI using EEC IV – which means you’d probably want to upgrade to any later SVO/Turbocoupe/XR4Ti engine harness and plumbing (Fuel injection/O2 sensor/Vane air meter – or better yet MAF). That is very easily accomplished when you find a donor car for parts, especially since you’ve already sourced a motor so you can just buy a shell with the appropriate wiring harnesses. You could even get lucky and find a car that has a T5 installed already (I’d look for a 88 Turbo Coupe as a donor – as I recall that was the first year the WC T5 was used in the Thunderbird. It also has the LA3 ECU which is very good, though an 85 SVO PE ECU would be even better in some instances.
The only issue with a V8 T5 is the input shaft diameter for the pilot bearing. However there are plug and play solutions to that - special pilot bearings.... The 2.3 bellhousing is of course required, but it can come from any 2.3 rear wheel drive Ford (the Lima 2.3 that is). That and finding the World Class T5. Check the tag on any potential T5 for it's actual spec's - just because it is in a Mustang V8 or I4 doesn't mean that was it's original home...
The nice thing is that there are places that still offer 2.3/2.5 performance items. Companies such as Esslinger, Racer Walsh, and 40BOB offer Turbo Ford parts, just to mention a few of them.
__________________
2005 Mustang V6 Convertible manual, no exterior emblems or tape, wing delete, Saleen Racecraft suspension, Saleen wheels, GT front fascia. GT Bullet takeoffs.
'06 Dodge RAM 3500 DRW QC LB Cummins G56 daily driver Power added by Mads Electronics
MarioP3_XR4Ti is offline   Reply With Quote
Old 06-27-2009, 10:29 PM   #3
Richter888
Default Good info
Heres a link
http://www.therangerstation.com/foru...thread.php?t=9
Richter888 is offline   Reply With Quote
Old 07-13-2009, 09:26 AM   #4
mopman93
Send a message via Yahoo to mopman93
When the engines switched to DP the front cover changed and they went to smaller journals. I believe that was in 91. And yes, the turbo motors can make power on stock bottom ends. I believe there is a guy on stingers website in the 10's on an untouched bottom end.
__________________
"Saying, 'I'm going to take my ball and go home' will be of no help, as we are well stocked in balls and don't need your wussy pink ball cluttering up the place anyway."
mopman93 is offline   Reply With Quote
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
