Go Back   MustangForums.com > Ford Mustang Tech > 4 Cylinder NA and Turbo > SVO Forum
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 05-27-2009, 08:13 AM   #1
hollcraft1
Default Cam Problem
I recently had my svo motor rebuilt. It was bored out a little, had some head work done and the came was made bigger. I don't know much but I trusted some one to help me. The problem is that I had a tapping sound so I took off the valve cover and found a rocker arm just laying there. I looked closer and seen that the lobe were the rocker arm cam off is flat and grooved, so the cam is bad. The guy that broke it in reved it up all the way to the red line amediatly and even blew off the intercooler at the throttle body. I need to know if it was broken in wrong or should I contact the machine shop. Thanks.
hollcraft1 is offline   Reply With Quote
Old 05-27-2009, 11:33 AM   #2
sleeper_inc
1988 FORD Mustang
sleeper_inc's Avatar
Vehicle: 1988, Mustang, LX
Car was broken in wrong, you go easy on the engine for the first couple 100 miles, then slowly turn the beating up.
Take it back, you should be running MINIMAL boost when breaking an engine in... if any boost at all.
__________________
1988 Mustang LX
Ex 2.3 N/A car, was a 2.3 turbo, now getting a complete forged & stroked 408W, shooting for a TT setup
1992 GMC Sonoma 4x4
185,000km's|4.3 auto|current DD getting 24mpg
1991 Mazda MX6 DX
299,000 km's (over 186K miles)| TOTALED!
sleeper_inc is offline   Reply With Quote
Old 05-27-2009, 08:28 PM   #3
mg man 75
1989 Ford Mustang
Vehicle: 1989 Mustang LX
I agree with Sleeper-inc. Should Have been broke in easy. It should not build boost or very little . This tell me the cam timing or ignition timing was wrong. I would go with stock cam, Ranger roller cam or Bopart cam. Here is how to check timing.
http://www.stinger-performance.com/tech.html
Camshaft breaking from Esslinger. No mention of red lining it. These people are the Gods of 2.3 for circle track and etc.
http://www.esslingeracing.com/tech/camshaft_breakin.pdf
Ask if valve lash was set? Here is procedure.
http://www.esslingeracing.com/tech/H...SETUP-TOOL.pdf
Good luck. Maurice
__________________
89 mustang 86 2.3turbo motor c-4 trans http://www.fquick.com/89-2.3turbo http://s177.photobucket.com/albums/w...20converiable/
mg man 75 is offline   Reply With Quote
46, 89, cam, ford, lash, mustang, problems, valve
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
