Go Back   MustangForums.com > Ford Mustang Tech > 4 Cylinder NA and Turbo > SVO Forum
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-01-2009, 09:31 PM   #11
TRBOPWR
Vehicle: 1985 SVOx2, 1986 SVO
Getting a V8 past the 13's isn't exactly a huge accomplishment. It takes more than exhaust and some boost to go 13's in these cars, but that is a very good first step. Drag radials help immensely.
__________________
Sig courtesy of Tombohum
1985 SVO 13.62 @ ~97mph with 1.74 60' and 20 psi, on the brakes trying to keep from breaking out!
TRBOPWR is offline   Reply With Quote
Old 10-22-2009, 10:15 PM   #12
ajs88
ok ok so I have full suspension, and a lot of supporting modifications and am finishing installing a fresh 88 tc block this weekend. I have an a/c removal, adjustable boost controller, adjustable fuel regulator, turbocoupe intercooler and aftermarket exhaust. I have my timing at 10* ( spout out) since that is what fmcdealer told me was base timing... What should my next step be? I want to get a launch controller and leave with full boost and some drag radials....any other reccomendations or ideas?
__________________
ajs88 is offline   Reply With Quote
Old 10-23-2009, 12:16 AM   #13
sleeper_inc
1988 FORD Mustang
sleeper_inc's Avatar
Vehicle: 1988, Mustang, LX
Get a good clutch
__________________
1988 Mustang LX
Ex 2.3 N/A car, was a 2.3 turbo, now getting a complete forged & stroked 408W, shooting for a TT setup
1992 GMC Sonoma 4x4
185,000km's|4.3 auto|current DD getting 24mpg
1991 Mazda MX6 DX
299,000 km's (over 186K miles)| TOTALED!
sleeper_inc is offline   Reply With Quote
Old 10-23-2009, 12:37 AM   #14
fast65
1984 Ford Mustang
My Garage
fast65's Avatar
Vehicle: 1965 Mustang GT, 1984 Mustang SVO
Send a message via AIM to fast65 Send a message via Yahoo to fast65
With these cars, do you have to go with a MegaSquirt system to get launch control? I know it comes as an option with one of Wilson Racing's kits.
__________________
'65 Mustang GT-stroker 347 w/Toploader 4-speed
'84 SVO-2.3T at 17 psi
fast65 is offline   Reply With Quote
Old 10-23-2009, 06:05 PM   #15
TRBOPWR
I'm pretty sure you would need some sort of aftermarket computer control (MegaSquirt) to launch with boost. Plus, once you start that the axles and 7.5 are only going to take the abuse for so long before bailing on you. Your first move should be a FMIC of some sort, they help out immensely. I dropped ~.3 and added ~3mph at the strip with only an intercooler swap. You could bump the timing up 2-4*, port the hell out of intake/head/manifold, and an adjustable cam or cam swap.
__________________
Old 10-24-2009, 01:42 PM   #16
Slow84SVO
Vehicle: '84 Ford Mustang SVO
get a die grinder(not dremel), spend 30 dollars in carbide cutting bits, 20 dollars in a felpro all cork/paper gasket set for a 2.3t and use the intake gaskets as templates. port out your lower to match that size for runners to head mating side. debur everything inside both plenums. also port match the lower to upper.
goto a pick and pull-get an npr intercooler. call kt a diesel radiator they wont know different. 30 bucks. spend 80 on an ic piping universal ebay kit. spend another 35 in an ebay manual boost controller. crank psi to 18. get a ranger roller too. if you arent 13s by then you have issues.
also you can look into a two step(ignition control) on summit. read up on it. you can set this up to "rev limit" to an ideal rpm to build boost while at the line.
the 2.3t block was a hi nickel content cast block. it ill handle a lot. the rods are the weak link. if you get over 350 horse you should invest in some forged rods. check out esslinger or racer walsh. you want 5.2" rods btw.
you can also knife edge the lower intake and gut/rotate the upper. but thats more complicated than easy backyard power. also i would hold off on trying to diy port the head if you dont know what you are doing. reading a few internet howtos wont properly teach you either. i have access to flowbenches and have ported a couple heads myself. trust me-send yours to boport or take it to a local reputable machinest if you are remotely unsure of yourself.
Slow84SVO is offline   Reply With Quote
Old 10-25-2009, 03:50 PM   #17
TRBOPWR
All very good info. Only thing I would consider is that a Ranger roller cam is not an improvement over the stock 86 slider unless it is completely worn out.
__________________
Old 10-25-2009, 05:10 PM   #18
Slow84SVO
i was under the impression that the roller had a slightly more aggressive grind, which coupled with the dual plug head gave the bump from 88hp to the 100+ factory rating. regardless that and the ford motorsport dirt track cam arent exactly ideal for the boost. but it sure is an improvement over the factory slider.
i thought the 86-88 turbo slider only had a bit more lift.? i dont recal. i havent had an 86+ oem slider to spec to a pre 86.
Old 10-25-2009, 05:16 PM   #19
TRBOPWR
I only know what I have read, the general consensus is that there really isn't much of an improvement. If I was gonna go to the trouble of swapping the cam, I would make sure it was a real strong upgrade.
__________________
Old 10-25-2009, 05:34 PM   #20
Slow84SVO
Esslinger street strip turbo roller *cough cough* only 900$. but is just go for a complete svo alum head w that shaft for $2100. and chuck in their billet 2.6l stroker kit for another 2500. hello tens. add a 150 squeeze, a viper spec t56, gr40 sla front end and 4link rear w a fab9 ford dif on coilovers plus a minitub and a full cage. mmm.(my current upgrade list). i think it will be mean enough to stomp tthe local vette club. goal is 650ponies at the rollers. and 25mpg. already sat down w turbo maps and specced everything. come on lottery.
1986, 23, 400, 400hp, 86, 86svo, adjust, cover, hp, litre, mustang, power, svo, timing, weak
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
