Go Back   MustangForums.com > Ford Mustang Tech > 4 Cylinder NA and Turbo > SVO Forum
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-17-2009, 08:21 PM   #1
alboy91lx
1984 Ford Mustang
My Garage
alboy91lx's Avatar
Vehicle: 1991 Mustang
Default turbo to manifold bolts?
what size are the bolts that bolt the turbo to the manifold? i noticed a leak after i got home from the track and found that both top bolts are missing and you can see a huge gap between the turbo and manifold... and whats the easiest way to replace the gasket?
__________________
"half assed equals half as fast"
84 Ford SVO
K&N Cone Filter
Aeromotive fuel pressure reg
Adjustible Boost Control
Stinger Performance 3 inch turbo back
17 psi of boost
and stupid flat top pistons!!! (bought car this way)
alboy91lx is offline   Reply With Quote
Old 08-17-2009, 08:53 PM   #2
evintho
evintho's Avatar
Vehicle: Turbocharged 1989 Mustang convertible
Cool
10mm x 1.5
ATP turbo has everything you need.................
http://www.atpturbo.com/Merchant2/me...egory_Code=FST
There is no easy way. Off comes the turbo. It's a little easier to remover the manifold and turbo as a unit. Make sure to modify the turbo brace while it's out. Makes it easier the next time the turbo has to come off!
__________________
Trust in the Lord with all your heart and lean not on your own understanding.
Proverbs 3:5
1989 Mustang convertible w/built and turbo'd 2.3.
evintho is offline   Reply With Quote
Old 08-17-2009, 09:17 PM   #3
alboy91lx
1984 Ford Mustang
My Garage
alboy91lx's Avatar
what do you mean modify the brace? i think i have the brace moved outa the way when i did the oil drain back... could this be way the bolts worked there way out?
__________________
84 Ford SVO
K&N Cone Filter
17 psi of boost
Old 08-18-2009, 09:15 PM   #4
evintho
evintho's Avatar
Cool
By modifying the brace I mean slot the 2 holes and grind away about 2" of the 'ears' on either side. This will allow you to remove/install the brace without removing the turbo and it facilitates removing the turbo without removing the manifold. It makes it a little bit easier. Did you have locknuts on the turbo studs? The factory nuts are the kind that are compressed to stop them from backing off.
__________________
Proverbs 3:5
Old 08-19-2009, 04:25 PM   #5
alboy91lx
1984 Ford Mustang
My Garage
alboy91lx's Avatar
on the turbo they have studs? its looks to me they have bolts that go into them... ill look at the bottom ones and see if they r studs or bolts... i was gonna put new bolts on the top with lockwashers on them...
__________________
84 Ford SVO
K&N Cone Filter
17 psi of boost
atp, atpturbocom, backing, bolting, bolts, bracing, exhaust, forums, gasket, manifold, matter, mustang, size, studs, turbo
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
