I heard this is a very helpful site, so here it goes ;D
okay.. so i have been rebuilding my 2.3t for my 93 mustang (notch) It is nearly finished just waiting on my pistons to get here. Here is what i have
-Fresh block bored .20 over (3.800)
-New crank
-New main bearings
-New rod bearings
-Stock 5.5 forged rods
-New forged speed pro pistons 3.800/96.5 mm
-Mildly ported and polished stock iron, bigger stainless steele valves
-Knife edged lower intake
-Gutted upper intake
-Stock 5.0 throttle body
-Front mount intercooler with 2.5" piping
-XSpwer turbo header ( factory turbo mount)
-Stock garret Airesearch t3 turbo (running 18-20 psi)
-3 inch exhaust from turbo back (dumped before rearend)
-35# injectors with factory 190 fuel pump.
-Stage 1 racer walsh cam.
-Centerforce dual friction clutch
-Aluminum flywheel
-Upr short throw shifter
-8.8 rearend with 273's ( looking for 355's or 373's)
-Run 92 octane
-A/c delete
-#1035 Fel-Pro head gasket, pre flattened copper wire ring
-Head studs
-I am using the la2 ECU
- Using large VAM
Thats it for now, just a couple questions, what should i expect for power wise? Am i gonna need to get it tuned what should i set my timing to, Thanks, any help is greatly appreciated, thanks for looking at my post.
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
Are your SpeedPros dished for lower compression? What's the part #? They don't look like these, do they?
If they do, back to the drawing board!
Set your initial timing to 10* BTDC but you can play with it and see where it likes it. Disconnect the IAC and set idle to 700-800. With IAC connected the idle should hover around 1000. Now set your TPS to .94v.
You should be able to hit 300hp with no problem. I saw no mention of an AFPR or adjustable cam sprocket. You should have both. Then find a quality shop in your area, take it in and have it dyno tuned. Best couple hundred $$$ you ever spent!
__________________
Trust in the Lord with all your heart and lean not on your own understanding.
Proverbs 3:5
Actually i ordered em about a week ago, they were on back order for like a week ina half, i should be getting them next week sometime, and thank you for the help i will be keep my post updated with the car. Thanks again
you say stock 5.5 rods. 5.5 is a "long rod" so are 5.7" the factory rod is a 5.2 just so you know. i hope you have 5.2s or else your piston will be making an unhappy hello with the roof of the combustion chamber.
also are you using a big main block or a small main block? i would also like to point out that the 1035 gasket is over rated. ive blown them on 24psi. i use the $10 na 2.3 paper felpro gasket. just spend 5 dollars on some spray paint, paint both sides of the gasket let it get really tacky(almost dry-very tar like) then put it on and torque the head as normal. i have had the same headgasket on my 2.3 as described for 16 of the 18 months ive owned it. its been mostly parked for the last 5months but ive had no issues with it.
