SVT Forums
HP Estimates
Old 01-06-2008, 01:26 PM
lasco10
lasco10's Avatar
Default HP Estimates
just wanted to get a rough idea on where the hp of my 04 cobra is heres the mod list
DiabloSport Tuner
3.10" upper 8#Lower
Spec Stage 3 Clutch
Fox Lake Short Block
Kooks LT's
CP Pistons
Manley Rods
Cobra Crank
CRP Head Studs
60 lb. Injectors
full exhaust not sure exactly what??
lasco10 is offline
Old 01-09-2008, 07:02 AM
CobraBob
CobraBob's Avatar
Default RE: HP Estimates
You didn't say you have a ported blower so I'll assume it isn't ported. You're running very high boost for an unported Eaton (around 16-17 lbs.). I'd venture to say you're up around 490-495rwhp with a good tune. If your blower is not ported I highly recommend you do it with that level of boost because blower inefficiences at that level are hurting you. Port the blower and you're looking then at around 530rwhp (Stiegemeier Stage 4 port). What fuel pumps are you using? And did you upgrade your meter?
CobraBob is offline
Aggiebq86
09-04-2015 12:20 PM
kdryan
The Racers Bench
08-22-2015 02:14 PM
svtrosey
SVT Forums
08-15-2015 09:09 PM
James Watson
08-06-2015 06:42 AM
Quick Reply: HP Estimates
