Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > SVT Forums
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 04-03-2008, 07:58 PM   #1
Venom8R
Send a message via AIM to Venom8R Send a message via Yahoo to Venom8R
Default Questions on rebuilding 96 Cobra motor
Well I think the head gaskets are blown on my Cobra. Its usin water and i can smell it out the exhaust. Doesnt leak it on the ground or in the engine oil so im assuming its getting into my cylinders. Sometimes when i first start it up and isnt hittin on all cylinders till it runs for about 30 sec to a minute then it runs fine. Hasnt lost any power or anything just have to add some water once every two weeks. So I guess its the headgastets? Anyways if it is the headgaskets it looks like i got to pull the motor. Since I got to do that might as well do other engine mods/fixes to it. Its got almost 119,000 on the motor. Doesnt use any oil and still runs awesome. Just wondering if there is somethin on these motors that should be replaced since its got a lot of miles on it. I was gonna replace seals and other things that go out over time. I was thinkin of gettin some aftermarket cams too. Any ideas on what kind of cams. Still want it streetable but more power. Best bang for your buck basically. What else should I do to it since Im doin this stuff? Any help would be great. New to the 4.6 motors. Thanks yall!
__________________
96 Cobra-Cobra R Rims, BBK Cold Air Intake, Flowmasters, Extreme headlights/tail lights, Lambo Door Kit
Venom8R is offline   Reply With Quote
Old 04-04-2008, 10:08 AM   #2
paulstang
Default RE: Questions on rebuilding 96 Cobra motor
Have you done a compression test? I just got done putting new head gaskets in my cobra and its not fun with the motor in the car.
__________________
95 Mustang gt RIP
85 gt RIP
96 Cobra
4:10 gears
MGW
Kenne bell 2.1
bbk offroad x-pipe to flows
WMS CAI kit
ls1 killer
paulstang is offline   Reply With Quote
Old 04-04-2008, 10:41 AM   #3
jlg32281
Vehicle: 1998, Ford, Cobra
You can do a simple block test. Autozone lends you the tool for free. You do have to buy a bottle of the solution that goes the tool. It test for exhaust gases in the coolant. It's the easiest way I know of for testing. It takes at most 5min. and you don't get dirty doing it. Just follow the instructions on the tool.
__________________
98 Cobra Coupe w/ shifter and Flowmaster, FRPP B springs, Tokico blues
jlg32281 is offline   Reply With Quote
Old 04-04-2008, 10:59 PM   #4
Ehmark
Vehicle: 1996 Cobra
Send a message via Yahoo to Ehmark
Thats crazy I didnt think it was possible to pull off the heads while its in the car on the 4v congrats. If your block test comes up ok check the heater core hose from the passenger head mine wasmessed upand I thought I had a headgasket leak.
Ehmark is offline   Reply With Quote
Old 04-05-2008, 02:15 AM   #5
paulstang
Yea its possible but such a pain to do.[&:] if i was to do it again i would pull the motor
__________________
95 Mustang gt RIP
85 gt RIP
96 Cobra
4:10 gears
MGW
Kenne bell 2.1
WMS CAI kit
ls1 killer
Old 04-06-2008, 01:00 AM   #6
NeoTokyo
Send a message via AIM to NeoTokyo Send a message via Yahoo to NeoTokyo
You need to understand that you need to have the block and heads resurfaced for the stock multy layer gasket to seal. There are other options to using the stock head gasket that does not require resurfacing.
Contact SHM (Sean Highland Motorsports)for more information.
__________________
95' Mustang Mach 1 281 manual - Penny -
Slightly Modded 4.6L / 5.3L ModStroker
RAM King Cobra Super Duty Clutch
White Ext. Charcoal Mach 1 Int.
Mach1 Shaker, badging/Clone
18"x10.5" Y2K Cobra R's
96' Mustang 00' Swap - NoName -
NeoTokyo is offline   Reply With Quote
Old 04-07-2008, 10:05 AM   #7
paulstang
Quote:
ORIGINAL: NeoTokyo
I couriousif this is true cause im having no problems and i didnt get mine resurfaced.
__________________
95 Mustang gt RIP
85 gt RIP
96 Cobra
4:10 gears
MGW
Kenne bell 2.1
WMS CAI kit
ls1 killer
1996, 96, cobra, gasket, head, highland, replacing, sean
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
