SVT Forums
Long Tube headers
Old 09-23-2008, 09:45 AM
pitmitch910
pitmitch910's Avatar
Default Long Tube headers
does anyone have a installation advice for installing BBK Long Tubes on my 97 Cobra? will the motor need to be jacked up or can it be done by dropping the k member? i have access to a lift so hopefuly that'll save me a lot of hassle. any advice is helpful
thanks
pitmitch910 is offline
Old 09-23-2008, 10:49 AM
contentsunderpressur
contentsunderpressur's Avatar
Droping the K-member and lowering the engine down a couple of inchs is by far the easiest thing to do.
contentsunderpressur is offline
Old 09-23-2008, 12:18 PM
pitmitch910
yea that was my plan, and the sounds the easiest if i use the lift
Old 09-24-2008, 10:45 AM
Blackvenom01
Blackvenom01's Avatar
im also doing headers and thinking bout doing the same thing but when i looked under my car there was nothin to hold the engine up between taking the k member off and then supporting it with a strap and hoist....any suggestions
Blackvenom01 is offline
Old 09-24-2008, 09:04 PM
pitmitch910
yea grant go get ur own damn thread lol, ill have to figure something out tho, hopeng to have them in by new years
Old 09-26-2008, 05:57 PM
pcs
pcs's Avatar
the first time i installed lt on my gt was on a lift but i just tilted the engine. if you drop the kmember you have to make sure that you align it back on right. tilting the engine was much easier than dropping the k member. just un-did the motor mount bolts and placed a block of wood under the oil pan, then jacked the engine over a bit. made plenty of room for the bbk headers.
pcs is offline
Old 09-27-2008, 04:34 PM
pitmitch910
yea, im thinkin about dropping the k member, i have aq bunch of connections like i can get a 20 dollar alignments, i have access to a lift, and tranny jack so thinkin droppin the k member and lowerng the motor down a few inches
Old 09-28-2008, 03:24 PM
pcs
pcs's Avatar
good luck
pcs is offline
Old 09-30-2008, 10:55 AM
pitmitch910
thanks ill need it
Jb145700
08-21-2022 06:37 AM
SSG Steggy
3.7L V6 Technical Discussions
11-05-2015 03:09 PM
Luke9222
10-22-2015 11:55 PM
PB Pod
Forum Issues and Feedback
09-17-2015 08:32 PM
BrantleyS550
09-14-2015 04:18 PM
Quick Reply: Long Tube headers
