Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > SVT Forums
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 03-02-2009, 10:54 PM   #1
MAD SVT
2003 Toyota Tundra
My Garage
MAD SVT's Avatar
Vehicle: '03 Cobra VERT
Default Little Known Facts about the 03/04 COBRA
Found this and got a kick out of it... copied and pasted
Credit goes to "Steeda04SVT" on SVTperformance.com
FACTS ABOUT THE 03/04 COBRA;
The 03 cobra motor has been outlawed from NASCAR, Formula 1, and CART, due to the unfair advantage any team using the motor would have.
The weakest part of the 03 Cobra's drivetrain is the driver's neck, which is typically the first thing to break during hard launches.
The 16 cylinder, quad turbocharged engine in the bugatti veyron is bugatti's strongest attempt at replicating the power generated by the 03 cobra.
If you see the driver of an 03 cobra walking with a limp, it is not because he hurt his back - it's from getting laid several times a day.
The movie "Terminator" is actually a simulation of what could happen if the 03 cobra motor was to become sentient.
Top Fuel drag cars are powered by 03 cobra motors with a pulley, long tubes and a tune.
There is no material/element in existence that would be strong enough to be used for the engine block of an 03 cobra with bolt-ons and nitrous.
When filming Fast and the Furious, to get the cars to do wheelies they just swapped in stock cobra motors.
The amount of power generated by an 03 cobra motor with only 6 spark plugs and mixed wires with 3 gallons of gas could power the entire Vegas strip for a week.
NASA recently announced that all future rocket launches will be powered by 03 cobra motors
If the 03 cobra motor had a penis it would be the biggest in the world.
It is possible to roast coffee beans with just the exhaust coming from an 03 cobra a block away.
To make a time machine you do not need a flux capacitor, just the 03 cobra motor. "Back to the Future" was actually based on a true story involving an 03 cobra, but was disguised as a delorean so as not to give away any big secrets.
The land speed record is held by an 03 cobra with a pulley on highway 9.
It is physically impossible to be late to anything anywhere EVER if you are driving an 03 cobra.
Scientists around the world are petitioning to include the 03 cobra motor in the periodic table of elements.
Other than diamond itself, the only other known element which can cut diamond is an 03 cobra motor.
If you ever run out of gas in a cobra, chances are your moving fast enough to coast to your destination.
The 03-04 cobra has been determined to be the most significant cause of global warming, simply due to the heat radiating from the exhaust because of the sheer amount of hp the engine generates.
Scientists hypothesize that by coupling an 03-04 cobra motor's flywheel to power plants around the world, we can permanently put an end to the power crisis.
If you have ever driven past a cobra mustang, it was either on the brakes hard or parked.
If a gay man drives an 03 cobra, he comes out of the experience a homophobic straight man with a wife and 3 kids.
It has been determined that it would be impossible to stop an 03 cobra with a head and cam swap, because there would be no way for commercially available brakes to stop the car.
99% of chevy and dodge guys have never driven an 03 cobra. This is a good thing, because if they did, GM and Chrystler would instantly go out of business due to a huge slump in car sales.
The nobel prize was awarded to the 03 cobra assembly manual.
The earth is being thrown off it's rotational axis by a man that mounted slicks on his 03 cobra and punched it from a stoplight.
Traction control was not invented prior to the discovery of the 03 cobra, as there was no need.
There are no commercially available tires which can harness the sheer torque produced by an 03 cobra.
The CHP ordered thousands of cobras but later backed out of the contract as they had a difficult time keeping the car straight and not wheelstanding
An 03-04 cobra could supplement the energy provided by the sun and bring an end to the next ice age.
The only WMD that needs to be sent to Iraq is an 03 cobra.
Default A Few more Facts about the 03-04 Cobra
On the 7th day, when God was pretending to rest, he designed the 03 cobra.
Lumberjacks use 03 cobra to uproot 300 year old redwood trees.
Freight trains are powered by cobra motors - however they need to be detuned to prevent the train from welding its wheels to the track.
A stock 03 Cobra with drag radials exerted so much force on the earth's surface that it created the volcanic chain known as the "ring of fire."
The power generated by an 03 Cobra motor can supplement the sun and bring an end to the next ice age.
An 03 Cobra motor is so powerful even superman is unable to handle the forces exerted under acceleration.
The Lockheed martin Joint Strike fighter disguises a cobra motor as a rocket engine to preserve the secret as to why it is superior to every other military plane ever made. Ever.
If a cobra motor was retuned to utilize its maximum capability, the engine would suck in so much oxygen that earth's atmosphere would collapse and all humans would cease to exist.
Hurricane Katrina was caused by the turbulent exhaust flow of an 03 Cobra driving down the highway at 7000 RPM.
An 03 Cobra motor does not actually require fuel. The fuel tank is merely attached to an independent mechanism that burns fuel to retain the secret that could drive all oil companies out of business and crumble global economies.
If we were to build a freeway into outer space, it would be possible to prove the theory of time travel using an 03 Cobra.
__________________
You just cant fix Stupid......
Check out my Termi Parts Garage Sale!! http://mustangforums.com/forum/new-e...bra-parts.html
MAD SVT is offline   Reply With Quote
Old 03-02-2009, 10:59 PM   #2
Mustang3GT07
Mustang3GT07's Avatar
Vehicle: 2004, Ford, Mustang Cobra
Send a message via AIM to Mustang3GT07
LoL....I can't believe I missed this over on SVTP.
__________________
2004 Cobra (Comp. Orange)
#3467 of 3768
-Tuned by Bob Kurgan
-485rwhp/506rwtq
2003 Ford Focus SVT
*Stock
2007 Mustang GT = Sold
2004 Mach1 = Sold
2001 Mustang GT = Sold
Mustang3GT07 is offline   Reply With Quote
Old 03-02-2009, 11:19 PM   #3
03svtcobra12
03svtcobra12's Avatar
Vehicle: 2003 cobra
lol thats like chuck norris facts for cobra lovers, pretty funny
__________________
03 cobra
467RWHP 510RWTQ
SOLD!
Next Car: 1967 Fastback
03svtcobra12 is offline   Reply With Quote
Old 03-02-2009, 11:26 PM   #4
1997Stang
1997Stang's Avatar
Vehicle: 2001 Mustang Cobra
Hahah thats awesome
__________________
2001 Lazer Red Metallic Cobra: 03/04 Cobra t56 transmission, Steeda Shifter, King Cobra clutch, 4.10 rear end gears, K&N intake filter, Bassani off-road X-pipe, Custom Catback exhaust, Diablosport Predator Handheld tuner, Ford Racing lowering springs, Chrome 03/04 Cobra wheels, Subframe connectors.
1997Stang is offline   Reply With Quote
Old 03-03-2009, 02:29 AM   #5
SVTeeshirt
Vehicle: 1996 Mustang Cobra
Quote:
my thoughts exactly, some were good some were meh.
__________________
Fastest Closet on MustangForums.
I bought a goldfish, named it after my ex-girlfriend, and let it die. It's really the little things in life.
SVTeeshirt is offline   Reply With Quote
Old 03-03-2009, 07:09 AM   #6
timspony
SVT Section Moderator
timspony's Avatar
Vehicle: 03 & 04 SVT Cobra
'03/04 Cobra FTW!
__________________
2003 SVT Cobra, DSG #7248 of 8394, Bassani Catted X, Flowmasters, JLT CAI, 2.76 BF Pulley, AFCO HE, PFab Tanks, SCT Xcal2, Pro 5.0, BF IRS Brace, Nitto 315 DR's...465 rwhp, 456 rwtq - Tuned by Mustang Magic!
2004 SVT Cobra, TR #269 of 1896 RagTop...Not Stock!
timspony is offline   Reply With Quote
Old 03-03-2009, 10:48 AM   #7
pitmitch910
1997 Ford Mustang
Vehicle: 1997 Mustang Cobra
hahaha funny
__________________
1997 SVT Cobra
BBK Ceramic Longtube Headers
BBK O/R-X Pipe
Bassani Catback
WMS Intake
SCT Xcal 3
Hurst Short Throw Shifter
Ford Racing Lowering Springs
HID Headlights
FR 500's
Window Tint
pitmitch910 is offline   Reply With Quote
Old 03-03-2009, 11:16 AM   #8
Yellow Fever
Just what I needed to brighten my day . Really funny .
__________________
Screamin Yellow 04' vert.Foose Nitrous 20's . Currently undergoing
a complete Cobra drivetrain swap .
Yellow Fever is offline   Reply With Quote
Old 03-03-2009, 04:13 PM   #9
1SVTLVR
1998 Ford Mustang
1SVTLVR's Avatar
Vehicle: 1998 Ford Mustang Cobra
Send a message via AIM to 1SVTLVR
Seconded! That was really funny lol
__________________
98 Cobra
Current Mods:
MMR Intake Spacer, Sniper Tuned 93 Octane, 4.10 Gears, JLT Cold Air Intake, BBK LTs, O/R Shorty H-pipe, Flowmasters, Short Throw Shifter (not sure which brand), 03 Cobra rims: 255/40/17 Front 315/40/17 Rear, Dark a** illegal tint. Saving up for the honda sticker purchase, haha
1SVTLVR is offline   Reply With Quote
Old 03-03-2009, 04:25 PM   #10
Blackvenom01
Vehicle: 2001 mustang cobra
Send a message via AIM to Blackvenom01
gotta love em
__________________
2001 Cobra Convertable
Bassani O/R X pipe
JLT Intake
SLP Loudmouth Catback
Bassani Longtubes
4.10 Gears
MGW Short Shifter
Nitto Drag Radials
95 Cobra R Chrome
Steeda UDP
X Cal 3
5% Tint
plus more....
RIP 2003 Mustang
Blackvenom01 is offline   Reply With Quote
03, 04, assembly, awarded, cobra, facts, last, long, manual, mustang, nobel, pa, plugs, prize, spark, svtperformance, the, tuning
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
