SVT Forums
01-04 Cobra trans question
Old 04-05-2009, 09:15 PM
69MustangCoupe393cid
69MustangCoupe393cid's Avatar
Default 01-04 Cobra trans question
Hey guys I am looking for a 6 speed out of a cobra, and wanted to get the strongest trans that was offered in the car. My question is, were the 6 speeds in 01-04 all the same, or did the supercharged cobras have a stronger t56 then the 01 and 02's?
69MustangCoupe393cid is offline
Old 04-06-2009, 01:09 AM
dirtydave289
dirtydave289's Avatar
i didn't think 01's had 6 speeds?
edit - and the cobra R's have a stronger t56 i believe..
dirtydave289 is offline
Old 04-06-2009, 03:05 AM
Oh I thought they did, I pretty much assumed that they had the 6 speed, can anyone confirm this? Ifthats the case I guess I'm lookign at 02-04 then. Also I'd love to get a Cobra R trans if it's stronger, but IIRC they only made 299 of them and I am sure it would cost a pretty penny if I even found one that someone was parting out.
Old 04-06-2009, 03:07 AM
primetime5.0
primetime5.0's Avatar
only 03-04 had the t-56 trans
primetime5.0 is offline
Old 04-06-2009, 09:08 AM
MAD SVT
MAD SVT's Avatar
no, the 2000 and the 03/04 have the T56, just buy an 03 that needs a rebuild, and rebuild it stronger if need be
what kind of power you making? the stock T56 can handle 500
MAD SVT is offline
Old 04-06-2009, 05:09 PM
ah ok so I need a supercharged cobra trans. Cool. Sounds like stock should be good for me at least for now, I'm making probably no more then 400hp and 450ft lbs and I don't foresee many more mods in the future. I have been debating a 150hp wetshot though which would put me over the hp levels of the stock tranny. How much is it to rebuild one of them with stronger internals?
Old 04-06-2009, 05:15 PM
mfj
Banned
mfj's Avatar
Stock Terminator T56's are RATED up to 450 lbs/ft torque, BUT there are PLENTY that have gone way past that level. With JUST an 26 spline input shaft, my t56 was holding my 700 lbs/ft of torque just fine... The stock 10 spline input shaft is the FIRST thing to go, in the tranny... Many have twisted them, with as little as 500 rwhp...
There are a handful of 9 sec Cobras running a stock T56, with JUST the input shaft/clutch upgrade...
mfj is offline
Old 04-06-2009, 07:35 PM
03_svt_cobra_22
03_svt_cobra_22's Avatar
^^^ +1000
03_svt_cobra_22 is offline
Old 04-06-2009, 07:43 PM
mfj
Banned
mfj's Avatar
In regards to your signature, there are NO M6 SRT 8's. They are ALL automatics...
mfj is offline
Old 04-06-2009, 07:51 PM
Sounds like the input shaft change is a good idea then, so where is a good place to get a new input shaft for these things? If I change the input shaft do you guys think the tranny will hold up to hard launches with drag slicks?
Quick Reply: 01-04 Cobra trans question
