Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > SVT Forums
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 07-03-2009, 07:02 PM   #1
dirtydave289
Vehicle: 1966 Coupe, 2003 Cobra
Send a message via AIM to dirtydave289
Default Kinda OT..just curious
Isn't there kinda rule-of-thumb for relating #'s of boost to hp gains?
Like the first 5 #'s give 9hp each, after that is 5hp each for example?
Maybe I'm crazy..could of sworn I heard that here lol
__________________
dirtydave289 is offline   Reply With Quote
Old 07-03-2009, 10:20 PM   #2
03svtcobra12
03svtcobra12's Avatar
Vehicle: 2003 cobra
its semi-relative, you can estimate that every 1lb of boost = xhp, I forget how you figure it out though
__________________
03 cobra
467RWHP 510RWTQ
SOLD!
Next Car: 1967 Fastback
03svtcobra12 is offline   Reply With Quote
Old 07-04-2009, 12:15 AM   #3
03svtcobra12
Vehicle: 2003 cobra
just did some reading, decent rule is 1lb = 5% of the engines N/A crank HP. this is purely an estimate and only accurate to certain levels, using the eaton as an example you may gain 40rwhp by going from 8psi to 12psi but once you over spin it you may loose power because it looses efficiency and cannot flow enough.
Just did some math, the estimated power of the 03-04 cobra motor is 300-320 NA, doing the math with the stated formula puts the crank hp at 415-430, the actual stock power level of the cobra, using 8psi.
And of course the biggest misconception with boost. Boost is a measure of restriction not flow. so i may be running 12lbs and making 500hp but then do some head work, better intake, CAI, full exhaust, and i may drop to 10lbs of boost but make 525hp. Those figures are just for an example btw.
__________________
03 cobra
467RWHP 510RWTQ
SOLD!
Old 07-04-2009, 12:47 AM   #4
dirtydave289
Oh yeah that's exactly what I was thinking..thanks for doing the research man!
__________________
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
