Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > SVT Forums
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 07-06-2009, 07:57 AM   #11
kweb288
1992 Ford Mustang
kweb288's Avatar
Vehicle: 1992, hatch
Quote:
Originally Posted by SVTeeshirt View Post
idk why you're running from pushrods.
tune on the engine wasnt spot on, burned up 3 pistons, used to have a 98 cobr and loved the engine, and to do a 351w i would need bout 6-8k
__________________
Currently putting an 04 cobra engine in my fox http://www.mymustangproject1.webs.com
kweb288 is offline   Reply With Quote
Old 07-06-2009, 07:59 AM   #12
kweb288
1992 Ford Mustang
kweb288's Avatar
Quote:
Originally Posted by Fobra View Post
for your 5.0... a dart block
dont have funds for it they r $2500 machined without ANY internals. swap is a lil more economical for me right now and looks cool
__________________
Old 07-06-2009, 10:29 PM   #13
SVTeeshirt
Vehicle: 1996 Mustang Cobra
4vs aren't cheap... for an aftermarket set of cams you're looking at ~$11-$1200, and
~$380 for valvesprings, not to mention you hit the wall @ ~ 390whp without boost on the 281 block.
__________________
Fastest Closet on MustangForums.
I bought a goldfish, named it after my ex-girlfriend, and let it die. It's really the little things in life.
SVTeeshirt is offline   Reply With Quote
Old 07-06-2009, 10:54 PM   #14
kweb288
1992 Ford Mustang
kweb288's Avatar
trust me i know all of this! i have choosen to go this way because i feel like it. I have many friends with 2v, 4v, 3v, and pushrod engines, I know what it takes to make power on them, im just looking for recomendations for the best building block
__________________
Old 07-07-2009, 12:46 AM   #15
pcs
pcs's Avatar
Vehicle: 99 gt and 03 cobra
Quote:
Originally Posted by 945LSTANG View Post
while the 99/01 had the better tumble port heads, the 96-98 had the teksid block, so i don't know if i agree.
i would go with the 98 and swap the heads if your budget allows.
99 cobras' had the teksid block too, it wasnt untill 01 when most all cobras had the WAP block.
__________________
35 anv GT (4.6 2v P1-SC 483hp/454ft-lbs @8psi)
06' daytona 675 (110rwhp)
89' jeep cherokee =) hp
03 cobra vert (429hp/421ft-lbs w/ 2.8 pulley)
06 suzuki ltr 450 (47whp)
pcs is offline   Reply With Quote
Old 07-07-2009, 02:25 AM   #16
SVTeeshirt
ok, i just wanted to make sure you knew what you were getting into. I would find a Teksid block, build the bottom end accordingly, depending on what your goals are the stock bottom end "prefered" power level is ~420whp before breaking ****, if you don't plan on going F/I you will be fine with hyper-teuntic(spelling) pistons + rods, (stock.)
if you do go F/i go forged H beams and pistons, all stock cobra cranks are forged, Teksids also come out of the 93-98? Mecury Mark VIIIs but i don't think they have a forged crank. I would try to pick up some 99/01 heads + intake(with the coolant problem fixed or buy new ones.) your best best is probably SVTPerformance, i got stock 01 heads complete and a 100mile takeoff 01 intake for ~$1000 i think a little less, i feel like i got a deal on that though, im going to be running these untill i can save up and get some ported 03 heads with blower cams and upgraded valves/springs/retainers/ valvejob.
__________________
Old 07-07-2009, 04:43 AM   #17
mfj
mfj's Avatar
Vehicle: Just Another Stang
Send a message via AIM to mfj
Both the 96-98 and the 99-01 Cobra bottom ends SUCK. Pretty much glass engines. The aluminum WAP block is crap from the 99-01's but the teksids from the 96-98 offer a much better foundation for some serious hp. But answer, both rotating assembly's are garbage, in the world of high hp. ****ty cast rods don't like to take abuse, and neither do the hypereutectic pistons...
__________________
Wisdom is simply the awareness of your own ignorance...
HAVOC
5.1L Stroker
Ported Heads
Stage 3 Comp Cams
3.4L Whipple @ 23psi
Solid Rear
Drag Suspension (UPR and STEEDA)
mfj is offline   Reply With Quote
Old 07-08-2009, 05:24 AM   #18
pcs
pcs's Avatar
for max hp durability the teksid is better but if you plan on running a really high hp car, either will work fine for just a street car with just a little extra kick.
and some 99 snakes did have a teksid block too.
__________________
Old 07-08-2009, 08:18 PM   #19
P.S.I.cho
1995 Ford Mustang
Quote:
yep pistons melt under any from of forced induction, and the cracked powder rods might as well be paper weights. we need more info on what your plan is, you putting in this motor to make a daily driver? or do u want something to go down the track
__________________
95 gt vert: 331 stroker, d-1sc @ 10 lbs,582 rwhp 511 ft. Tq
2003 sonic blue cobra KB 2.2 @ 19psi,supporting mod, solid 8.8 601 rwhp 584 rwtq
F/S 99-04 anderson pms piggyback tuner, 331 stroker, stock t-5, stock 8.8" 3.73 rearend
http://www.cardomain.com/id/moocow_v
my videos
http://videos.streetfire.net/uploaded/vertstang95.htm
http://www.youtube.com/watch?v=NdptbEq5UJU
P.S.I.cho is offline   Reply With Quote
Old 07-08-2009, 11:52 PM   #20
kweb288
1992 Ford Mustang
kweb288's Avatar
Quote:
o its a track car and i know about stock stuff that ford puts in there engines.... just needed info on the blocks, know about forced induction too, burnt up my pushrod pistons cause of a bad tune
__________________
2004, 46, 4v, 51, 9698, 98, aluminator, block, cobra, d1sc, ford, gt, long, mmr, mustang, stroker
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
