When I depress the clutch in my 99 Cobra, the RPM increases to about 3000. The dealer changed the throttle position sensor and connector but the problem continued. They discussed with Ford SVT and they suggested repacing the wires from the computer to the sensor which they did. Still does the same. It has happened in hot stop and go traffic in LA and cool temps driving in the mountains??????
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
Does your vehicle have crusie control? If so, try disconnecting the cruise cable from the throttle bracket underhood and see if it continues....just a thought
__________________
2000 GT 5 Spd
BBK Fenderwell, Trickflow 75mm Plenum, Summit 75mm TB, Steeda Triax, King Cobra Clutch, FRPP Flywheel, Steeda Cable Adjuster/Quadrant, SLP catted X-pipe, SLP LM1 exhaust, Sniper SF Tuning, Weld in Full Length SFCs, FRPP 4.10 Gears, Carbon Clutch Discs.
Wish list....
KB blower
Rear suspension-UCAs & LCAs in a box-need a free weekend to install
Tubular front suspension
Long tubes
We think alike. I looked under the hood the first time it happened and that was the only mechanical linkage other than the throttle. Needless to say, that wasn't it. Thanks for the thought!
