Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > SVT Forums
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-14-2009, 02:04 PM   #1
89lxhatch
Vehicle: 89 lx hatch
Default 4.6 dohc
im looking to swap a 4.6 dohc cobra motor into my 89 lx 5.0 what is the differences in the dohc motors between 99 and 2004, besides the obvious supercharger and hp ratings, are they pretty much the same internally, and are the blocks the same? Are the heads different, just curious, cause i can get the termi motor for 9000 dollars with tranny and fuel system ecu and wiring harness, but i can get a 99 motor with the fuel system ecu and harness for 3500, so if i just add the supercharger to 99 motor will it basically be the same as the 03 motors? Not wanting to sound dumb but just really curious the differences
89lxhatch is offline   Reply With Quote
Old 09-14-2009, 05:33 PM   #2
hot sauce
Vehicle: 2004,ford cobra
03/04 motor iron block.forged internals,c heads( i think there came on the fr500s someone correct me if i am wrong),better cams,low compression,t56 trans,the 03/04 motor is 100x better then the 99 motor.
hot sauce is offline   Reply With Quote
Old 09-14-2009, 09:40 PM   #3
pcs
pcs's Avatar
Vehicle: 99 gt and 03 cobra
i wouldnt say 100x better but better out of the box
99/01 snakes have an alum block and the 03/04 have an iron block
the cams are better for a blower application but not necisarly better.
03/04 have the forged piston,rods,crank and the 99/01 only have a forged crank.
both are 'C' heads but the 03/04 heads flow better stock but ported neither is better.
which engine is better for u? if you want to crank out >500whp and u cant redo an engine yourself, then the 03/04 is better. if money is an issue u can get the 99 cobra engine and slap a s/c on it for less but you are going to be limit to <500whp due to the weak pistons and rods.
__________________
35 anv GT (4.6 2v P1-SC 483hp/454ft-lbs @8psi)
06' daytona 675 (110rwhp)
89' jeep cherokee =) hp
03 cobra vert (429hp/421ft-lbs w/ 2.8 pulley)
06 suzuki ltr 450 (47whp)
pcs is offline   Reply With Quote
Old 09-14-2009, 11:23 PM   #4
89lxhatch
ok your saying 99/01 is the 02 cobra motor the same as the 03 minus the s/c then?
Old 09-20-2009, 03:43 PM   #5
darkstarnes
darkstarnes's Avatar
Vehicle: 35th anniversary GT
Quote:
nope way different... 03/04 cobras have forged internals... and 99/01 dont maybe just the crank like some one said but not sure about that one... and as far as I know the heads in 03/04 are not C heads.. any one correct me if I am wrong...
__________________
borla catback
O/R X pipe
dragradials
3.73 gears
diablo tune
darkstarnes is offline   Reply With Quote
Old 09-21-2009, 10:00 PM   #6
pcs
pcs's Avatar
Quote:
quick info. their was no 02 cobra in the states, a few were made and sent over seas but no 02 models here. 99/01 snakes use an alum block vs the iron block of the 03/04, so they are not the same. all mod cobras have a forged cranks and the heads from the 99/01 snake look the same as the 03/04, i have both sets. both are C heads but the 03/04 heads are suppose to flow better out of the box. when ported the only difference between to 2 would be the port job.
__________________
Old 09-21-2009, 10:23 PM   #7
Xemeth
Vehicle: 2002 GT
Send a message via AIM to Xemeth
The 99-04 heads are all considered C heads, but the 99/01 Cobra heads are a bit different. The 03/04 Cobras and Mach's have the same heads. I believe it's the exhaust ports that were slightly altered on the newer heads, but they're all C heads.
__________________
2002 GT, H/C/I 4v.
Xemeth is online now   Reply With Quote
Old 09-22-2009, 10:52 AM   #8
Mach1man
Vehicle: 2003 Mustang Mach 1
My advice, split the difference and buy a brand new Aluminator motor from the Ford Racing Performance Parts catalog.
Essentially, it's an 03/04 Cobra motor with an aluminum block, all forged internals, and available in either high compression N/A, or low compression S/C versions. The complete long block is in the 6k neighborhood, and comes with a 12 month/12k mile warranty.
__________________
2003 Torch Red Ford Mustang Mach 1 5-speed
527.52 RWHP 495.15 RWTQ @16lbs. on 93 Octane
My Mods
My Car
MODS: Yeah, it's got mods.
Mach1man is offline   Reply With Quote
03, 04, 2004, 46, 99, cobra, dohc, engine, f150, ford, forged, hp, mach, mustang, pistons, svt, swap
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
