SVT Forums
97 cobra sc losing oil pressure, help??
Old 09-22-2009, 04:56 PM
sacpoole
sacpoole's Avatar
Default 97 cobra sc losing oil pressure, help??
I have a 97 cobra with a V-1 vortech sc. just recently the engine started losing power and shutting off. the oil pressure will drop to zero. but here is where it really has me, the oil pressure gage will bounce around and then even out at normal but when it does the engine starts a slight knock on the passenger side, then it will drop back to zero and knocking will stop. from everything i know it seems that it should be the other way around...please help
sacpoole is offline
Old 09-22-2009, 05:44 PM
5.0 85 GT
5.0 85 GT's Avatar
sounds like your oil pump **** the bed....that knock is not good, bottom end???
5.0 85 GT is offline
Old 09-22-2009, 11:52 PM
300Z5
300Z5's Avatar
mine usto knock like that when i start it cold, got worse after a while then suddenly a piston rod broke lol. had a spun rod bearing, have it checkd out asap man
300Z5 is offline
11-10-2015 11:39 AM
svfetter
10-05-2015 11:39 AM
88 orangepeel notch
10-05-2015 09:03 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: 97 cobra sc losing oil pressure, help??
