Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > SVT Forums
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-23-2009, 02:45 AM   #1
Sizeth3
Vehicle: 1982 Chevrolet Camaro
Default Chirping sound from 2001 Cobra
Hey my 2001 Cobra with 56k miles is making a chirping noise at idle. If I barely touch the clutch it goes away. It sounds like a slipping belt but I was curious why the clutch would matter? Anything else I should think about?
Also how long does a clutch typical last in a Cobra like mine? Am I getting close to replacement time? How can you tell?
__________________
2001 Laser Red Metallic Ford Mustang Cobra
Bassani Cat Back
Sizeth3 is offline   Reply With Quote
Old 09-23-2009, 03:19 PM   #2
hot sauce
Vehicle: 2004,ford cobra
sounds like your throw out bearing is about to check out! i dont really think you can gauge how long a clutch will due to the fact everyone drives different,if you go to the track alot, or if you ride to pedal alot or cant really drive a manual.
hot sauce is offline   Reply With Quote
Old 09-23-2009, 03:21 PM   #3
Sizeth3
What happens if the throwout bearing goes out?
__________________
Bassani Cat Back
Old 09-25-2009, 05:06 PM   #4
nascrchi
Vehicle: 1996 Ford Mustang
yep! throwout bearing needs to be replaced! I hate that sound! happened to me for power shifting :/ time for a new clutch!
__________________
my only motivation!
nascrchi is offline   Reply With Quote
Old 09-25-2009, 05:19 PM   #5
timspony
SVT Section Moderator
timspony's Avatar
Vehicle: 03 & 04 SVT Cobra
+1 on the throw-out-bearing!
__________________
2003 SVT Cobra, DSG #7248 of 8394, Bassani Catted X, Flowmasters, JLT CAI, 2.76 BF Pulley, AFCO HE, PFab Tanks, SCT Xcal2, Pro 5.0, BF IRS Brace, Nitto 315 DR's...465 rwhp, 456 rwtq - Tuned by Mustang Magic!
2004 SVT Cobra, TR #269 of 1896 RagTop...Not Stock!
timspony is offline   Reply With Quote
Old 09-30-2009, 10:44 PM   #6
Reikat
is there anything else it could possibly be? I ask this because I just recently had my transmission rebuilt and a new ram hdx clutch put in, and I'm haveing this same problem. Could it just be loose or need to be fitted differently or is it for sure going bad?
__________________
97 SVT Cobra... loving that 4v V8
(Sig change coming soon)
Reikat is offline   Reply With Quote
Old 10-01-2009, 12:44 PM   #7
ATFPat
ATFPat's Avatar
Vehicle: 2003 Ford Mustang Cobra
I m getting the same like thing with my 03 cobra with only 13,000 miles on it. Started when I put a different pullley on the blower and was told it was the belt and not to worry. I don't beat the car at all so if its a transmission thing then I ll be pretty pissed. Drives fine though and never had any problems.
__________________
SLP Cat-back w/high flow cats
JLT CAI
H&R Sport Spring w/camber kit
BBS Rk's (18x8.5F/18x10.5R)
Accufab Throttle body - Diablo sport tuner
Steeda (2.81) Pulley w/tensioner
LFP Rad/heatexchanger.
and more ????.............
Bottles are for babies, real men get BLOWN!!
ATFPat is offline   Reply With Quote
Old 10-22-2009, 08:42 AM   #8
my97cobra
1997 Ford Mustang
my97cobra's Avatar
Vehicle: 97, mustang, cobra
My whole reason for getting the clutch replaced was due to the noise your explaining. I put my car on ramps along with jack stands for double safety, put the car in nuetral, emergency brake for additional safety, started the car, remove the inspection cover on the tranny and sure enough found my chirping bird. I was almost positive it was that but wanted to see it for myself. If you do ge the clutch replaced or even just the throwout bearing (you should do it all at the same time if the tranny has to be removed) make sure it's installed right. I am going through a nighmare right now with a repair shop that has F'd mine all up. Due to improperly installing the throwout bearing it has chewed the fingers up on the pressure plate. This was a "all parts new" install. They also said they didn't need to do anything to the flywheel. It was ok. Try going back to RAM or any other clutch manufacture for warranty issues and tell them you didn't get the flywheel done. Waste of time.
On the clutch fork there are 2 retainer fingers that have to be on the inside of throwout bearing sleeve not outside like mine are right now. This causes the clutch pedal to rattle real bad and has already worn out my bearing.
__________________
Johnny Parker
my97cobra is offline   Reply With Quote
03, 2001, 2003, 2007, 2010, 46, bearing, chirping, cobra, engine, ford, mustang, noise, sound, sounds, throw
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
