Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > SVT Forums
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-20-2009, 02:25 PM   #1
my97cobra
1997 Ford Mustang
my97cobra's Avatar
Vehicle: 97, mustang, cobra
Default Clutch Firewall Adapter
I am going to replace my stock quadrant with an aftermarket one and install a firewall adapter so I can adjust my clutch. My question is the stock quadrant has a tension spring but once that's removed what pulls the clutch pedal back? Do you have to design your own? Not a problem if so but I'm sure otheres have already doen this. Ideas/suggestions?? Should I say what keeps the throwout bearing off the clutch plate fingers so it doesn't prematurely wear.
__________________
Johnny Parker
my97cobra is offline   Reply With Quote
Old 10-22-2009, 08:20 AM   #2
my97cobra
1997 Ford Mustang
my97cobra's Avatar
Default Clutch pedal rattle anyone? Found my reason!!
Quote:
Update...the whole reason for wanting to install the aftermarket quadrant was due to my clutch pedal rattling. I finally found the problem. The repair shop installed the throwout bearing wrong. On the clutch release lever there are retainer fingers that have to be on the inside of the throwout bearing sleeve not the outside. If they are on the outside like mine are the release lever will wobble causing the clutch pedal to rattle and push the throwout bearing tight againt the pressure plate fingers. Now it's time to fight with the repair shop that did the work. They said the problem was probably due to the quadrant. NOT. I ordered the aftermarket quadrant and cable adjuster but decided to take a closer look at it myself last night. I'm glad I did. So....for anyone with clutch pedal rattles take a look at how the throwout bearing is installed.
__________________
Johnny Parker
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
