Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > SVT Forums
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-04-2009, 09:22 PM   #1
00_whitesxr
Send a message via Yahoo to 00_whitesxr
Default Build engine or drop an 03-04 termi engine?
so i have a 99 cobra which according to some tranny mechanic the engine locked up. i kinda dont wanna believe him cuz the i thought wen that happened the engine is suppose to smoke wen it happens or watever. the only thing the car did was throw sparks under the car when i missed third. i figured it was something with the tranny but then i got that answer that my engine was locked. so my question would it be better to build the engine it has now or get the termi engine and do whatever i need to drop that engine in? I would glaldy appreciate any help thanks
__________________
00_whitesxr is offline   Reply With Quote
Old 11-05-2009, 01:06 AM   #2
RedHousePainter
RedHousePainter's Avatar
Vehicle: 2001 SVT Cobra
So when you missed third did your engine lock up immediately? And now it won't crank over?
RedHousePainter is offline   Reply With Quote
Old 11-05-2009, 09:52 AM   #3
hot sauce
Vehicle: 2004,ford cobra
Quote:
if you saw sparks shoot out from under the car you should see a hole,crack of something! try and take off you ur belt and see if you car will turn over. my a/c compressor seized up on me before and it shot sparks everywhere and would not let the engine turn over making me thing the engine had locked up.
hot sauce is offline   Reply With Quote
Old 11-05-2009, 11:05 AM   #4
jthorn9
CSMG Moderator
jthorn9's Avatar
Vehicle: 1995 Mustang GT, 2000 Mustang
I'll say this, if you can afford a Terminator engine and T-56 tranny assembly, then go for it, but if you're not that rich, then find and fix the problem you have now, cause that will still be the cheapest route. I doubt the engine locked up on you, I really don't see any way for that to have happened unless something internally failed.
__________________
Trinity 99 Mustang SVT Cobra
Selena 95 Mustang SVO GT-40 1.5L 11PSI Kenne Bell Supercharger
jthorn9 is offline   Reply With Quote
Old 11-05-2009, 11:34 AM   #5
CobraCurt
Vehicle: 2003 Ford SVT Mustang Cobra
Quote:
^^^this
__________________
2003 Mustang Cobra
CobraCurt is offline   Reply With Quote
Old 11-05-2009, 12:50 PM   #6
Fobra
I would pull the heads and get a built short block... it would be a better way to go, then add a blower
__________________
TRADE MY Mach 1 HOOD + scoop set up for easy GT install (attached, no intake system necessary, unless you want it) for a COWL hood and maybe STOCK + CASH (but probably not). The hood is painted silver, in great shape, does need a color sand, but thats no biggie. Would prefer a swap for a silver one, but will consider many options. Need to trade due to changed plan on this car. RTP/Greensboro/Charlotte
Fobra is offline   Reply With Quote
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
