SS brake lines for '97 Cobra?
I purchased a set of Stainless Steel brake hoses for my '97 Cobra. But the kit only comes with the 4 Caliper hoses and not the rear chassis to rear end hose.
Does anyone know where I can buy the single SS hose that goes from the Chassis to the rear end? I have had no luck finding one.
Also, I am rebuilding my braking system and will be draining all the brake fluid. How much total brake fluid will I need to totally refill the system? I am keeping all the OEM Calipers.
Maybe Jazzer has an idea?
there is no flexible hose like on the Fox chassis on the SN95 chassis. It will make sense when you go to change the hoses. They route the mainline to the passenger side and have a Y block that than runs over to the driver side. and the fluid will very depending on how much air is in the system during the bleeding process. Just get a couple of quarts it's not like brake fluid is expensive
11-10-2015 11:39 AM
09-16-2015 07:53 PM
09-08-2015 11:50 AM
