SVT Forums
Oil in COP holes?
Old 09-25-2012, 03:22 PM
rfomlover
rfomlover's Avatar
Default Oil in COP holes?
Is this supposed to happen? I took the COPs out and there is so much oil in some of these holes I cant even see the plug!!!
rfomlover is offline
Old 09-25-2012, 06:52 PM
1998Slow 'Stang
1998Slow 'Stang's Avatar
The seals inside the cam cover that go around the spark plug wells are gone....it's a fairly common issue on most DOHC motors I have seen. If they are not there, there is a gap you could stick a fingernail in between the cover and the well.
1998Slow 'Stang is offline
Old 09-27-2012, 02:51 PM
cease4
cease4's Avatar
When you buy a valve cover gasket kit it comes with the o rings that seal the spark plug holes...if its the driver side you will have to remove the hydroboost and master cylinder in order to get it out
cease4 is offline
jwog666
12-27-2021 08:09 PM
jrrhd73must
10-02-2015 09:17 PM
wraith777
09-28-2015 10:49 AM
EASTIDEE123
09-15-2015 11:08 AM
MusicCity615
09-12-2015 07:05 AM
Quick Reply: Oil in COP holes?
