car storage
car storage
this is going to be my first winter with my 99 and just wanted to know what ppl do durning storage months. i had a bike for years and did nothing with it expect put rubber mats under the wheels and later a battery tender. i will be storing the car at my house and will be able to start the car hopefully once a month. ne1 have ne different storage/winterizing habits?
Last year was my 1st winter with my car, I used car cover and battery tender. I put heavy duty plastic on garage floor under car. I found industrial carpet squares with a rubber backing to put under the tires, I put bounce dryer sheets in car, trunk and exhaust outlets this was supposed to keep rodents away. I started car once a month and went for short ride around neighborhood for about 30 to 40 min. I do not have a heated garage and saw no ill affects from doing this.
Put stabil in the gas tank and let it sit untill you bring it back out for the season, idle and short trips do more harm than good for storage as the vehicle doesn't get hot enough to burn off all the nasties. If you do not have a garage I recommend putting it in a storage unit and no cover needed.
