HELP!!! mach 460 issues
I really could use a visual on how the amps from the mach 460 are hooked up. I purchased this car from a dealer auction (01 cobra convertible with 30k), the one issue I'm having is that someone tampered with the amp set up and the wires are messed up. The radio currently works but has a monotone sound since the amps are not hooked up. if someone could show a proper set up of this would be deeply appreciated.
I will try to get you a pic, but something to check would be to see if you are getting power to the amps (red wire maybe, should be hot when car is in run or accy, and also check ground), and if the amp turn-on is working (blue wire from head unit, should go hot when head unit is turned on). The amps have a separate fuse in the fuse box under the driver side dash (at least on mine) that would be a good place to check first if not getting power.
If you just want a wiring diagram... I have seen them floating around. Cliffy has a lot of good stuff on his site:
www.paladinmicro.com
