SVT Forums
engine shut down
Old 10-18-2013, 09:32 PM
cobra961000
cobra961000's Avatar
Default engine shut down
I've got a 96 Cobra and had the unfortunate opportunity to take a picture of it behind a tow truck today.
Here's what happened, maybe you can help me figure out what's wrong.
After driving a couple of miles the car turned off while sitting at idle at a red light. The RPM dipped from about 900 to 600 (normal for mine) a couple of times then dipped again and shut off. When I tried to re-start it, the engine didn't move. The dash lights came on, the windows and radio worked but the engine didn't turn. After about 90 seconds or so, it fired right up. I made it another couple of miles and it did it again. Exact same issue, eventually I was able to get it off the road and wait for the tow man.
Looking at the engine, everything looked clean and connected. It didn't sputter or whine when I turned it over again and the check engine light didn't come on. The light as come on in the past and the code read about a censor. I'm not sure if it was a fuel or o2.
The theft light didn't come on and after 90 seconds the car started right up. What do you think it is?
cobra961000 is offline
Old 10-20-2013, 05:01 PM
reldla1996
reldla1996's Avatar
Not sure what you meant by "engine didn't move", but it sounds like an ignition problem of some sort. Start by reading codes and see if they tell you anything.
reldla1996 is offline
Nick Oliver
10-17-2018 04:22 AM
AmericanMuscle4.6GT
11-10-2015 02:06 PM
rksnow1
09-14-2015 08:46 PM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: engine shut down
