Water in door panel after wash/rain?
Old 12-17-2014, 09:03 AM
thay83
thay83's Avatar
Default Water in door panel after wash/rain?
Maybe I'm just being over protective of my new car, but if I roll down the windows 3-4 days AFTER I wash the car (or if it rains), the glass will come back WET when rolled back up.
I realize it's probably just moisture trapped between squeegee layers of the weather stripping, but in my mind the interior of my door panel is a humid swamp of old car wash moisture, slowing rusting into oblivion...
This is on the new 2015 model so I was also wondering if it's an issue with the weather stripping.. or maybe Ford just needed to design some better air holes in the door?
Let me know what your thoughts are or if you've seen/heard of this before.
Thanks!
thay83 is offline
Old 12-17-2014, 10:17 AM
jz78817
jz78817's Avatar
Thanks!
the interior of the door is a wet zone, and is designed as such. The weatherstripping can't be a perfect seal, if it was you'd never be able to roll the windows up or down. and yeah, the part which touches the glass has a felt material on it which can stay moist for a while.
jz78817 is offline
Old 12-17-2014, 11:15 AM
ZGrand
ZGrand's Avatar
3-4 days does seem excessive. Is it both windows?
ZGrand is offline
Old 12-17-2014, 01:10 PM
amptor
amptor's Avatar
The water drains down into the door sill area. When it rains, the water drains through the door into there. It is designed to do that. If you are getting water puddling up inside the cabin where you put your feet, I would be concerned. I doubt this is happening. I can see where your concern comes from too because I noticed this happening recently as well but that is because I had the car garaged for a long time and really didn't have it out in the rain a lot.
amptor is offline
Old 12-17-2014, 01:53 PM
thay83
thay83's Avatar
A felt-like material probably explains it perfectly.. that hadn't occurred to me. I assumed it was a series of rubber seals that deflect water from pouring inside the door in between it and the glass. Also hadn't heard of the interior door being a wet zone, though I'm sure that explains the sheets of plastic you'll usually find on the inside to separate the outer door from the inner paneling.
Yes it's both windows. The cool and cloudy conditions here recently probably prolong the drying.
Nope, no water inside the car! I'd be back at the dealers lot before the first rain drop ever hit the floor. Just that new car paranoia about that moisture in the door.
Thanks for the input guys!
thay83 is offline
Old 12-17-2014, 02:53 PM
WJBertrand
WJBertrand's Avatar
Open your doors and look at the bottom edges and confirm the little drain holes / slots are open.
WJBertrand is offline
Old 12-18-2014, 05:40 AM
pascal
S197 Section Modder-ator
pascal's Avatar
Everything's normal and nothing is gonna rust anytime soon.
Just drive the car and have a blast.
pascal is offline
Old 12-18-2014, 06:23 AM
jz78817
jz78817's Avatar
yes, they're called water shields. I think you can guess why...
jz78817 is offline
Old 12-18-2014, 08:37 AM
FordService
Official Ford Rep
FordService's Avatar
Thanks!
Hi thay83,
Welcome to the forum! My name is Deysha with Ford Service. I see these awesome guys have answered your questions, so I just wanted to stop by and congratulate you on your new ‘Stang.
Deysha
FordService is offline
Old 12-21-2014, 09:45 AM
JIM5.0
JIM5.0's Avatar
Rained on me the other day. Had this same problem. Water will not drain out of the door.
Can someone post where I need to look to see these door drain holes? I need to unclog mine.
EDIT: WHOOPS! Please ignore. Wrong forum. My doors are the 2011-2014 S197, not S550 doors
JIM5.0 is offline
Quick Reply: Water in door panel after wash/rain?
