New McLeod Racing Ecoboost Mustang Clutch Disc Upgrade
We're proud to announce the release of the McLeod Racing clutch disc upgrade for the 2015-2016 Ecoboost Mustang.
This clutch disc upgrade is designed to work with your factory pressure plate, flywheel and hydraulic slave cylinder. Simply remove your factory clutch disc and replace it with this one and you're good to go.
We tested this upgrade last week at the dragstip and went 11.93@114 and the clutch holds excellent. Not only does it hold the extra power we're throwing at it the feel and engagement of it is identical to stock. No chatter and no heavy pedal feel whatsoever.
http://www.lethalperformance.com/sho...s-upgrade.html
The McLeod 600 series clutch upgrade disc for the 2015-2016 Ecoboost Mustang is a direct replacement for the factory disc. It still utilizes the factory pressure plate, flywheel and hydraulic bearing. By swapping this clutch disc into your car you drastically increase holding capacity but still maintain the same excellent driving characteristics that the factory clutch has to offer.
The 600 series is the ultimate High Performcance disc in the single disc platform. Suited for both street and strip duty, the 600 series will give you both the smooth engagement and holding power you need to get the job done. This disc has a segmented semi metallic ceramic facing on both sides of the disc.
Having all of the horsepower in the world won't do you any good if you can't get it hooked up when you need it. That's where McLeod Racing clutch discs come into the picture. They're available in a variety of friction materials to help you get it all hooked up, including organic, ceramic and kevlar®. In addition, they're made in several distinct series, with applications to fit a wide range of vehicles, including those for both street and strip use.
Give us a call if you have any questions or need assistance placing the order.
Thanks, Jared
Thanks, Jared
01-06-2016 07:03 PM
mustangsrforever!!!
08-06-2015 12:04 PM
