New car leaking brake fluid
Old 04-10-2016, 10:11 AM
saintsokwitit@yahoo.com
saintsokwitit@yahoo.com's Avatar
Default New car leaking brake fluid
My 2 month old GT is leaking brake severely to the point where It's leaking down from Max to Min every 3 days. It all started last weekend coming back from Houston when I had to slam on the brakes and the ABS kicked in and the brake warning light came on. 3 days later the fluid had leaked down and I brought it to the dealership and they didn't find anything.
I made another appt with dealership for Monday morning and they will keep it all day to check it out better to hopefully find issue.
Oh yeah 2200 miles total on car and you would expect that a high performance car could take slamming on the brakes without having an issue.
saintsokwitit@yahoo.com is offline
Old 04-10-2016, 12:46 PM
jwog666
jwog666's Avatar
any car can have a problem with a part, mustangs are no exception. have them find the problem and fix it. a leak is a leak, and will be simple to find. fluid doesnt just vanish. however, a small leak that results in fluid loss over a long time, can be a bit harder to pinpoint than a leak that results in a puddle under the car and a brake pedal that goes to the floor, give them time to find it before you get frustrated
jwog666 is offline
Old 04-10-2016, 01:45 PM
I think I will just be happy if they find the leak and fix it. I know getting frustrated won't help the situation so I'm going to try and keep and positive attitude.
Old 04-10-2016, 02:23 PM
One of my friends just found the leak coming from the clutch pedal on the inside of the car. My carpet and floor mats are saturated with brake fluid and you can see it dripping now that he spotted it. I'm wondering if steam cleaning the carpet will be good enough or what will need to be done with them.
Now I'm getting frustrated.
Old 04-10-2016, 02:33 PM
jz78817
jz78817's Avatar
I don't know if the Mustang uses the same master cylinder, but:
http://www.autoblog.com/2016/03/04/f...igation-nhtsa/
jz78817 is offline
Old 04-10-2016, 02:59 PM
It kind of sounds like the same condition that I was experiencing.
Old 04-12-2016, 06:14 AM
mmdpg
mmdpg's Avatar
I think the brakes and clutch use the same fluid reservoir so there is a good chance there is nothing wrong with your brakes, the leak in your clutch is what's draining the system.
mmdpg is offline
Old 04-12-2016, 08:38 AM
proeagles
proeagles's Avatar
I would insist the dealer replace the carpet under warranty.
proeagles is offline
Old 04-12-2016, 09:22 AM
movielover40
movielover40's Avatar
Absolutely demand carpet be replaced.
movielover40 is offline
Old 04-12-2016, 09:32 AM
Shaq74
Shaq74's Avatar
Carpet replacement. Brake fluid can even damage paint
Shaq74 is offline
Quick Reply: New car leaking brake fluid
