What aftermarket air filter?
Old 06-11-2016, 06:53 AM
PNYXPRESS
PNYXPRESS's Avatar
Originally Posted by scottmach
This
Oh, I'm sorry, I didn't realize my dyno results of stock vs cai only gain was not correct. And since we all know the plastic tube yielded 0 gain it must of been the filter.
Common sense will also tell you that a filter that is less restrictive will provide power gains at the cost of less filtration.
Again, the small hp gain is not the reason to buy a drop in filter, the cost of savings over the life of the vehicle by not buying filters is.
Also by using a less restrictive filter you will see an increase in fuel mileage IF you drive the same conditions as with the paper filter.
PNYXPRESS is offline
Old 06-11-2016, 10:19 AM
69mach1377
69mach1377's Avatar
3-7 hp may just be the diff between a clean and dirty filter...
69mach1377 is offline
Old 06-11-2016, 05:29 PM
scottmach
scottmach's Avatar
So then post up your "supposed" dyno results of a 2015 since that's the section we're in. I'll await your results.
scottmach is offline
scooter3
04-12-2016 03:02 AM
Mach2
03-26-2016 01:49 AM
Burtonsnow157
13
03-23-2016 11:06 PM
1973sd455
03-22-2016 07:15 PM
Andii
03-18-2016 09:17 AM
Quick Reply: What aftermarket air filter?
