295 size tires on all 4 corners?
Old 07-11-2016, 01:43 PM
Apexcarver33
Apexcarver33's Avatar
Default 295 size tires on all 4 corners?
Is it possible to squeeze 295s under all four corners of a 2016 Mustang GT? I know they will fit on the rear and I am looking for guidance on the front.
The car started life as a performance package set up; however, I recently converted to Koni Yellows, set of linear rate springs and BMR sway bars.
Apexcarver33 is offline
Old 07-16-2016, 11:01 AM
squishbang
squishbang's Avatar
Front wheels are 9" and the rears are 9.5" so the answer is: no
squishbang is offline
Old 07-16-2016, 01:56 PM
pascal
S197 Section Modder-ator
pascal's Avatar
295s will fit on a 9" rim, I've done it. But it was on a 20 inch rim on a 06 Stang...and depending on the offset, it could rub the sway bar or inside the rail or both.
pascal is offline
Old 07-16-2016, 03:53 PM
Apexcarver33
Default I have my solution
Cortex Racing has a coil over set up that will allow me to run my desired tire size or larger, up to a 305.
Old 07-16-2016, 04:52 PM
pascal
pascal's Avatar
You're good then...
The reason I went 295s is because I tried to have a bit of a bulge to protect the rim from the ex-wife curbs parking lots escapades but she still managed to fugg up 2 sets of rims in 4 years or so. lol
pascal is offline
03-07-2016 05:04 PM
Mustang Videos
03-04-2016 01:26 PM
DerekShiekhi
03-03-2016 04:40 AM
fastbackford351
02-22-2016 06:27 AM
mohammadkhannj@gmail.com
02-21-2016 03:01 PM
Quick Reply: 295 size tires on all 4 corners?
