Factory Style Spoiler Labor Cost?
Old 08-30-2015, 10:46 PM
jink21
jink21's Avatar
Default Factory Style Spoiler Labor Cost?
I am planning on ordering a factory style rear spoiler for my '15 V6. There were two types of spoilers available, 3M tape or screw on. After conducting some research I figured I would go with the screw on because I would feel more assured that it is going to be more secure.
I am a little iffy about drilling the holes in myself, mostly because I am not experienced. Additionally the trunk area isn't flat and the area the spoiler would fit on is kind on an incline. Do you guys think I should still try do it myself and save costs or go to an auto-shop and pay them to fit it on there?
Thanks for everyone's help.
Here's the link: http://www.carid.com/2015-ford-musta...-53241256.html
jink21 is offline
Old 09-03-2015, 09:35 AM
Mignav001
Mignav001's Avatar
I'm all for doing things yourself. But when it comes to drilling holes into a car... especially the exterior, I say let the pros do it, so they can cover the cost if they screw up
Mignav001 is offline
Old 09-03-2015, 11:04 AM
PNYXPRESS
PNYXPRESS's Avatar
Its not that complicated of a task.
Take a piece of posterboard and trace and press the spoiler and bolts thru it. This will give you a flat template to use.
Line up the template on the trunklid and center it, taping it down good.
Double, triple measure and then measure again.--key is to make sure its absoluetly straight and centered on the car.
next set the spoiler in place on top of the template lining up the bolts with the holes in template making sure it stays lined up where you want it.
Use a punch to put a small dimple in all the holes where you will drill. Using a small drill bit carefully drill a pilot hole in each dimple and them using the smallest bit possible drill a hole the bolts will fit thru.
PNYXPRESS is offline
jrrhd73must
10-02-2015 09:17 PM
breaking
10-02-2015 01:27 PM
1996cobraconvertible
SVT Forums
09-30-2015 02:01 PM
Drastang
09-30-2015 03:48 AM
GLOCKer
09-28-2015 07:36 AM
Quick Reply: Factory Style Spoiler Labor Cost?
