The Mustang doesn't come with a spare tire?
Old 04-01-2016, 06:23 PM
jz78817
jz78817's Avatar
Originally Posted by jwog666
the factory 20 in wheels would make a spare with the same diameter too large to fit in the trunk, ford gives you sealant and an inflator kit instead. bc lets face it who the f wants to put a chitty looking spare on any way, plus technically they are limited to 50 mph for a short distance. so if you have a flat and want to fix it correctly you would head directly to a shop and fix/replace the tire anyway
I had bad luck with tires on my 2012. Driving through an area with road construction, I hit a chunk of popped-up concrete which tore a hole in the sidewall of my left rear tire. no goop or compressor is going to get me back on the road after that.
jz78817 is offline
Old 04-01-2016, 06:37 PM
buckethead2
buckethead2's Avatar
Originally Posted by 09GT/CS
Agreed with the above. Most two doors and sporty cars now come with the repair kits or run flats. It's not really a new practice even full size trucks come with donut spares now go figure. It also helps save weight those spares and jacks/tools weigh a good bit.
Full size trucks come with donut spares? Mt F150 didn't.
And how could a 1 ton dualie use a donut?
Anyway,thanks for all the info. I guess I got behind the times.
buckethead2 is offline
Old 04-01-2016, 11:09 PM
jwog666
jwog666's Avatar
the determinnig factor on if its a space saver spare it the size of the factory rim, larger rim/tire combos wont fit between the frame rails, so they use smaller spares in place. a dual f350, has a wider frame rail setup, and the tires arent larger for show, its a work truck. so yes they use a full size spare.
jwog666 is offline
Old 04-02-2016, 10:35 AM
09GT/CS
09GT/CS's Avatar
Yeah it lasted about a year or two the gov tried to mandate to force people to replace tires instead of riding the full size spare. ( genius idea about reducing abandoned vehicles). The full size was still an option on the trucks and they may now be back to full size spare as standard. But I remember looking a few years ago and every f150 on the lot had a donut for a spare. I thought they were nuts.
09GT/CS is offline
Old 04-02-2016, 12:29 PM
C6 VETTE
C6 VETTE's Avatar
At least Ford provides a inflation kit. Corvettes for example, have runflats. I prefer the tire inflation kit over runflats due to price of purchasing new tires. Runflats cost about 20% more than the same brand non-runflat tire.
C6 VETTE is offline
Old 04-06-2016, 08:58 AM
Yours Truly
Yours Truly's Avatar
Just ordered a spare tire kit from dealer. $250 worth of insurance. I was surprised to see it cheaper than a mustang specialty store that caters to forums like this.
Yours Truly is offline
Old 04-06-2016, 10:24 AM
mmdpg
mmdpg's Avatar
https://www.partscheap.com/2015-2016...3z-1k007-c.htm
mmdpg is offline
Old 04-06-2016, 10:55 PM
C6 VETTE
C6 VETTE's Avatar
They want an additional $200 roughly for a spare tire. If its a full size spare cool, if it's a donut then blah!
C6 VETTE is offline
Old 04-07-2016, 09:29 AM
jz78817
jz78817's Avatar
it's not quite a donut, but it's still a temporary spare. it's large enough in diameter where you can use it on the rear and not worry about your differential.
jz78817 is offline
Old 06-19-2016, 11:11 PM
Intrepid175
Intrepid175's Avatar
Not all flats are fixable with fix-a-flat. If all I did was local driving, I wouldn't mind having just the repair kit but I wouldn't want to be out in the middle of nowhere, a hundred mile from the nearest tire store without a spare tire. Unfortunately, if you order the performance package, you can't get the spare tire anyway, at least according to the "build it" section of Ford's web site.
Intrepid175 is offline
Quick Reply: The Mustang doesn't come with a spare tire?
