Old 10-22-2015, 05:43 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Ford Mustang Interior Guides
Print Wikipost
Removing Door Panels/Rear Deck
Old 12-20-2014, 07:40 PM
keithgt2015
keithgt2015's Avatar
Default Removing Door Panels/Rear Deck
Does anyone have detailed instructions on how to remove the door panels and/or rear deck on a 2015 Mustang. I am planning on replacing the door and rear speakers. I have done this on many different vehicles; however, I have been unable to locate vehicle-specific information on the new Mustangs. I am not comfortable with just trying to figure it out on a brand new car.
Thanks.
keithgt2015 is offline
Old 12-20-2014, 10:58 PM
ticopowell
ticopowell's Avatar
I can't imagine that they would be too different from the 2014. I would start with the rear seats, then the side plastic panels, and then the back cover... unless they are accessible from the trunk. I doubt that you can get to the screws from the trunk, but if you can that would be a great start .
Not that that was help, but it might be , good luck!
ticopowell is offline
Old 12-21-2014, 12:47 AM
Mr. D
Mr. D's Avatar
Thanks.
Ford is trying to protect the car from you! (Smile)
Mr. D is offline
Old 12-21-2014, 09:22 AM
keithgt2015
Thanks. I agree that the rear panel may not be much different. However, I am concerned about tearing into the door panels without specific directions for the 2015 as the door panels are different. Just don't want to break anything.
Thanks
Keith
Old 12-24-2014, 01:11 AM
ticopowell
ticopowell's Avatar
Definitely understandable. I would bet that taking them off isn't different than the S197's. There are probably 3-4 screws on the bottom, 2 along the edge of the door, 2 big torx bolts, 1 by the handle, and 1 by the door opening handle, and then probably 1 more normal one by the window and locking switches, just take that panel off... It is probably worth a look at those spots, and all around the door to see if there are any more... taking it off shouldn't take too much pressure and it is easy to tell if you missed a screw.
sorry I can't help more. Good luck!
jerrytubes
10-23-2015 12:11 PM
Dathan
10-05-2015 05:52 AM
jrrhd73must
10-02-2015 09:17 PM
09-25-2015 06:58 PM
Quick Reply: Removing Door Panels/Rear Deck
