Go Back   MustangForums.com > Speed Zone > Street/Strip > The Racers Bench
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-14-2009, 05:51 PM   #1
Shaunmac9128
2001 Ford Mustang
Vehicle: 2001, Mustang, V6 Convertible
Default Advice on first visit to the track?
I'm hoping to get one or two runs in before the year is over. I have never been to the strip before but I want to go to get a good number of what my car will do before and after some new mods. Not looking for criticizing, I know its not fast hoping for mid to low 16's as its my first time. So I am looking for some advice, maybe what to set my tire psi at or something. ****ty tires, running fuzion hri's running low on tread on stock 16's but I'm really not sure. Just looking for some advice on what to do, and some ideas of what you guys think I might run/trap so I know what to shoot for. Mods are in my sig. Thanks. It will be at New England Dragway btw.
__________________
16.17 @ 86.19mph 2.35 60'
Shaunmac9128 is offline   Reply With Quote
Old 10-14-2009, 06:07 PM   #2
socalwrench
socalwrench's Avatar
Vehicle: 2008 Mustang V8
If you've never raced at the drag strip before, I would advise just making sure you don't do anything stupid. Honestly, just worry about yourself and the car. You probably don't need to use the burnout box, especially with worn out radial tires- so you can drive around it. If you drive the car to the track- there should already be some heat in them anyway.
Before your second pass- you can start playing with air pressure. As a GENERAL rule, lowering the air pressure increases grip while upping it does the opposite. I used to air up my fronts 4-6 psi (less rolling resistance) and air down my rears 6-8 psi (better traction). Pressures depend on several factors but lowering them from your normal psi should give you slightly better off-the-line traction.
Also, depending on how much time you have between runs- you can open up your hood and/or ice down the intake for a small gain.
__________________
Greg - Owner/Operator: GRH Performance
socalwrench is offline   Reply With Quote
Old 10-14-2009, 07:33 PM   #3
Shaunmac9128
2001 Ford Mustang
Thanks for the advice. I will be driving it there. And since I still have an open diff the burnout box would be pointless. Maybe I will try and lower the rears just a few when I get there.
__________________
Old 10-16-2009, 07:52 PM   #4
mustangman02232
mustangman02232's Avatar
Vehicle: 04 F350 6.0
Send a message via AIM to mustangman02232 Send a message via Yahoo to mustangman02232
run the MAX tire PSi on the sidewall in the front tires, rears at 30 psi, drive AROUND the burnout box, (there is no need for you to go near it without DRs, and dont track water down the track (turn off AC to)) stall the car to about ~1000 rpms, leave on the last yellow. i had similar mods but but with LTs and was running high 15s
__________________
2004 Ford F350 6.0 PSD
MBRP 4" turbo back, no muffler/kitty, autometer boost/pyro/trans, SCT X-cal with innovative tunes, MISC appearance, fisher MM2,
not installed: arp head studs, cooling mods, 03 turbo, cfm "small mouth" elbow, ARP head studs, BPD EGR delete
SOLD:
2002 Mustang v6 vert
LTs, catted H, K&N FIPK, SCT X-3 with vmp tunes, misc appearance
RIP tripsevn7
4/1/77 - 7/27/08
mustangman02232 is offline   Reply With Quote
Old 10-18-2009, 04:59 PM   #5
Shaunmac9128
2001 Ford Mustang
Yeah I remember that, which is why I'm hoping for somewhere in the 16's since its my first visit. And leave on the last yellow?
__________________
Old 10-18-2009, 05:14 PM   #6
98LS1
Send a message via AIM to 98LS1
Reaction times doesn't matter. You can sit there for 10 seconds after the green, although I don't recommend it, and it still will not affect your time in a test and tune scenario.
My only WOW, words of wisdom for the lamen, don't wreck.
__________________
2000 FRC M6
Heads/Cam/75 shot/Stock intake/Ported stock TB
3.90 gear
10.7 @ 130 mph
6.8 @ 104 mph
1998 TransAm SOLD!
Cam only, 8.8" rear, 4.10's
500rwhp/496rwtq
Dry kit/stock fuel system
Idle Video
˙ǝɹnʇɐuƃıs ʎɯ uı pǝʇsǝɹǝʇuı ʎllɐǝɹ ǝɹɐ noʎ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
98LS1 is offline   Reply With Quote
Old 10-24-2009, 06:16 PM   #7
TommyV8
2002 Chevrolet Camaro
TommyV8's Avatar
Vehicle: 2002 Chevrolet Camaro Z28
The best advice for someone who's never been there is to watch other people run for a while first, so that you get a good idea of what to do. Staging can be especially confusing. I think there's a sticky in this forum for you to read.
__________________
2002 Camaro Z28 Mulletmobile
Automatic, 3.42 gears, stock converter
Airbox lid, full exhaust, drag radials
12.76 @ 109.76, 1.92 60 ft
TommyV8 is offline   Reply With Quote
Old 10-25-2009, 11:17 AM   #8
Shaunmac9128
2001 Ford Mustang
Yeah I did have to watch others but I had a good idea what I was doing. Either way my best run was 16.1 at 86mph with a 2.3 60'. It was a great time, really enjoyed it. Can't wait to go back after my 8.8 and 4.10 swap. But that was the last open night for the season.
__________________
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
