Go Back   MustangForums.com > Speed Zone > Street/Strip > The Racers Bench
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-26-2009, 08:48 PM   #1
lbballin9
2005 Ford Mustang
lbballin9's Avatar
Vehicle: 05 Mustang GT
Default New numbers...what should i run?
my buddy doesnt have enough posts to start his own thread so he will on here....pervious numbers are 347hp and 352 tq on 6lbs of boost...he went and got a smaller pulley and power pipe and re-tuned today...new numbers are 394hp and 402 tq on 10 lbs of boost....his best run previously was 13.2 @ 108 my question is what should he be running and trapping?
__________________
K&N CAI
Flowmaster Exhaust
TB Spacer
Billet LCA's
Steeda UCA
Kooks LT's & O/R X
Grantelli UDP's
93 Oct Sniper Tune
3.55 Gears
B&M STS
311 rwhp/330 rwtq
lbballin9 is offline   Reply With Quote
Old 10-26-2009, 09:13 PM   #2
mustang51js
Vehicle: 2002 mustang gt
i didnt know you needed a minimum amount of post to start a thread, anyway was the first set of numbers the tune that came with the sc, they are the exact numbers i got on my car with a vortech and its tune.What year car is it and what type of supercharger, is that the anderson pipe and what size pulley did he swap to. Im going to geuss and say 12.5 with the new numbers.
__________________
02 black gt,vortech sc,3.25 pulley swap,air to air intercooler,anderson powerpipe,3.90 motive gears,aluminum drive shaft,75mm tb,75mm trick flow plenum,38lb injectors,lowering springs,cobra rims front 245/45/17 rear315/30/17,summit racing o/r h-pipe,sss terminator cat-back,CHE LCA'S, Ford racing UCA's. 90mm lightning maf and sctx3 tune
mustang51js is offline   Reply With Quote
Old 10-27-2009, 10:40 AM   #3
lbballin9
2005 Ford Mustang
lbballin9's Avatar
Quote:
Originally Posted by mustang51js View Post
i didn't know you needed a minimum amount of post to start a thread, anyway was the first set of numbers the tune that came with the sc, they are the exact numbers i got on my car with a vortech and its tune.What year car is it and what type of supercharger, is that the Anderson pipe and what size pulley did he swap to. Im going to guess and say 12.5 with the new numbers.
He has a 2004 4.6 2v with o/r H and weld in flows, 75mm throttle and plenum, vortech V2 with the 3.33 pulley and 10lbs of boost. Yes the Anderson power pipe, its a very mild tune for the pulley but stock bottom end and internals, so didn't want to go too extreme and blow it.... street tires on the stock 17's...tires are 245/45/17's and had mmr upper and lower control arms.
__________________
K&N CAI
Flowmaster Exhaust
TB Spacer
Billet LCA's
Steeda UCA
Kooks LT's & O/R X
Grantelli UDP's
93 Oct Sniper Tune
3.55 Gears
B&M STS
311 rwhp/330 rwtq
Old 11-07-2009, 07:20 AM   #4
ctgreddy
Vehicle: '95 gt 347
Well he's not going to hook so I'm going to say high 12's but with a trap of around 115 or so. Now if he borrowed some slicks or even some decent dr's I'd be dissapointed with anything slower than a high 11.
__________________
'95 Mustang GT- 347. Canfield 195's. Holley systemax. CI custom cam. 31 spline 8.8 w/ 4.10's. TKO 3550.
12.8@112; 339/365 with a bad tune.
ctgreddy is offline   Reply With Quote
Old 11-09-2009, 11:55 PM   #5
acarzt
acarzt's Avatar
Vehicle: 2008 Mustang GT
i'm gonna guess a 12.6@112
__________________
'08 Alloy GT Manual
Audio:
Eclipse Navi/DVD/BT/Ipod/etc. Polk speakers, Alpine Type R 12" w/Alpine 600w Amp.
Performance:
Steeda CAI w/CF elbow, SCT x3 w/Brenspeed 93 octane tune
Pypes M80 Mufflers welded in
CMDPs
Track:
13.67@103.77 w/2.13 60'
(13.37@106 corrected for DA)
acarzt is offline   Reply With Quote
Old 11-10-2009, 12:55 AM   #6
Grabber
2003 Ford Mustang
Grabber's Avatar
Vehicle: 2003 Cobra
I'd say a 12.4-12.5 @ 111-112 if he can drive, and has decent traction.
__________________
2003 10th Anni Torch Red Cobra 462 RWHP 486 RWTQ SAE
Fluidyne Heat Exchanger
H&R Springs
K&N FIPK
Mac O/R Prochamber and Borla Stinger C/B
BF 2.76 Pulley
LDC Chicago HCM
Many more mods
Grabber is offline   Reply With Quote
Old 11-10-2009, 01:22 AM   #7
GrnBullitt08
2008 Ford Mustang
GrnBullitt08's Avatar
Vehicle: 2008 Bullitt #2479
He wont hook up with those tires....I'm saying 12.7-12.8. Traction is everything unfortunatley. Tell him to lay off uping the hp until he gets a new set of tires.
With a set of drag radials or slicks, He's capable of low 12's possible high 11's if he can drive, as stated above.
__________________
SALEEN EXTREME CAI - BRENSPEED SCT TUNE - MMR TB SPACER - BBK LONGTUBES - BBK OR X-PIPE - FRPP GT500KR AXLEBACKS - FRPP 3.73s - FR500s - NITTOS....AND SOME OTHER STUFF
GrnBullitt08 is offline   Reply With Quote
Old 11-10-2009, 08:32 AM   #8
mrtstang
Vehicle: 2004, Ford, Mustang Gt
With those dinky 245 street tires i'd say between a 12.8-13.0 at 113-116 mph.
__________________
2004 DSG Mustang Gt, BBK long tubes, BBK catted h pipe, SSS Terminator Catback, K&N cai, Steeda UDP's, Accufab 75mm tb/plenum, FRPP aluminum ds, Motive 3.90 gear, Alternative Auto custom tune, Steeda Tri-Ax, DD black bullitts w/315's Nitto 555R's, & 100 shot N20. 269/305 na, 373/528 N20
mrtstang is online now   Reply With Quote
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
