Another what will it do thread... new SS mods
Since my last trip to the track, temps have broke a bit and I have added some more mods to my SloBalt SS/SC. On my last trip, I was only able to make two passes due to the crowd. It had a catted 3" downpipe, heat exchanger, 2.8 pulley, 60lb injectors, modded air box, and a dyno tune last time I ran. It made 240 wheel HP at the time, and ran a 13.9 at 103 mph, 2.1 60'. It was in the upper 80s when I ran.
This weekend I am returning with the addition of a shorty header (3" collector Vs the stock 2"), a larger 2.5 inch inlet/outlet glass pack in place of the stock 2" inlet/outlet resonator, as well as a welded in magnaflow muffler, and an Injen cold air intake. Any chance this thing will gain 4 tenths between the new mods and cooler temps? I know it sounds like a lot to ask for, but the car has been responding really well to mods so far. Its supposed to be in the low 70s this weekend.
Sorry for starting a thread about this instead of just running it and reporting the ETs. Its been a while since I've had time to get to the track, so I'm getting anxious.
I've got the slip (kind of) under control. I have to completely lift off the throttle, get off the clutch hard, then punch it again. It will hold as long as the clutch is completely engaged before I get back on the gas. A new clutch is going in, its just a high dollar fix, and I had a few other things I had to cover first so it got put on hold for awhile. I'm looking at the Exedy clutches.
I don't know about all that, lol! ^^^
I'm going to have to either spray it or ditch the M62 Charger for a turbo, TVS, or twincharge set-up, to make a beast out of it. I believe the best anyone has done with the stock M62 is a high 12, but that was with tires, meth, pretty much everything. That's my goal to start with...... then I may try to do something to give you a run
I spent right at $2200 on my S197 to run low 13s.....
I'm thinking the same thing. I'm running it in Fayetteville. How far are you from there?
Bout 2.5 hours....give or take. I actually was gonna go to school there for the Professional Golf Management program at Methodist College. You a member of HPJ.com? May have asked you that before....bad memory + drinking a lot = repeated questions.
