The Racers Bench Is the track just too much for you? Want to know what will beat what? Talk about it here!!
Weight reduction, 100 lbs = .25 seconds?
Old 09-27-2011, 12:13 AM
justinschmidt1
justinschmidt1's Avatar
Default Weight reduction, 100 lbs = .25 seconds?
Just saw a show called car science on speed where they stripped the hell out of a nissan sentra.
I believe they ended up gaining about .25 second for each 100 lbs they removed.
Of course, It probably a bit different when the car runs 16s to begin with and has no torque but it was still pretty interesting.
Weight reduction is where its at.
justinschmidt1 is offline
Old 09-27-2011, 12:27 AM
perfect.disguise
perfect.disguise's Avatar
I could get mine in the low 2700's pretty easy, though I doubt I will spend the time to do it next time I hit the strip.
I always heard the common rule of thumb in 100lbs= .1
perfect.disguise is offline
Old 09-27-2011, 01:35 AM
3.0Taurass
3.0Taurass's Avatar
I'd say it also depends on the initial weight of the car. Stripping 100lbs out of a v6 challenger isn't going to help as much as stripping 100lbs out of a 3000lb car IMO.
3.0Taurass is offline
Old 09-27-2011, 03:23 AM
buster
buster's Avatar
I once tried this and it didnt make too much difference. Besides if you race a 14 sec car, u r going to run bracket anyways. I once raced with my golf clubs and a bunch of other crap in my trunk.
buster is offline
Old 09-27-2011, 08:01 AM
justinschmidt1
Yep,
Ive always heard that two...
just thought it was crazy that they removed 500 lbs an ended up running like 1.4 seconds faster.
But yea, Im sure it is differant if you have a fast car already vs a 17 second sentra that they tested on and like I said, im sure if you have a car withj some torque, the weight becomes less effective.
Old 09-27-2011, 10:16 AM
bluebeastsrt
bluebeastsrt's Avatar
Hot rod magazine did a pretty cool article on weight reduction back in the day. Called caddy hack. Later it did Corvette Hack. Pretty interesting, took a saw to a car and seen how fast it would go just from removing parts of the car..
http://hotrod.automotive.com/145803/...est/index.html
http://hotrod.automotive.com/74264/h...ght/index.html
bluebeastsrt is offline
Old 09-27-2011, 04:07 PM
aerbourne
aerbourne's Avatar
saw this same show last night haha
aerbourne is offline
Old 09-27-2011, 06:58 PM
justinschmidt1
Lol @ caddy hack.
In the case of Caddy Hack, we took a 6,780-pound car that ran 17.22 at 80 mph and turned it into a 2,900-pound car that ran 13.55 and 100 mph
3880 lbs reduced and ran 3.7 seconds faster, that one did turn out to be about .1 for every 100 lbs.
baddog671
07-26-2016 01:20 PM
Explosive
10-02-2015 07:45 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
mdg
10-01-2015 07:04 AM
guitarman376
09-30-2015 05:54 PM
Quick Reply: Weight reduction, 100 lbs = .25 seconds?
