10s on stock block or rod through stock block?
Roll of the dice? I know 10s have been done on stock bottom end 3v cars before. Just read of one yesterday. He got 3 attempts in before it blew up.
How does the 2v setup compare to the 3v? Apologies in advance if you feel this is directing away from the question in the OP.
lol, Im going with the first one
Last edited by Stkjock; 10-12-2011 at 07:47 PM. Reason: Please use the multi quote feature and edit function
In that case anything over 500@ the crank and you are pushing it.
That said I know of at least one stock motor that lived quite a long time and with track use at 570@ the tire. It never blew, the owner put in a built SB before that happened.
Depends on the set up. if you're staying s/c then I say nuh uh. she's gonna blow. but if you swap to a turbo or even nitrous then it's doable. there's a couple people I know of (one turbo one nitrous) on stock bottom end that are really close to 10's.
I've seen the random video on youtube where the guy claims 450rwhp+ from his 2V, stock bottom end (maybe stock heads/cams too)...but then a few months later is the comment in the comments section about how it blew up.
If you are adding a lot more power then I think its going to split.
