How much rwhp to hit 11s with turbo???
I'm not running anything higher than 3.27s. The only direction I'd go is lower to 3.08s. Turbos love load. I also don't see why I couldn't cut a 1.8, that's nothing special. I guess only time will tell
I'm assuming 8psi would get me in the power level of 11s. Spring time needs to get here so I can install everything and take it to the track.
I didn't want to come off rude I'm just saying from all the turbo setups I've seen the guys going fast aren't running anything more than 3.55s, most guys deeping in the 10s or even lower ETs are running 3.08-3.27 gears.
And spooling won't take 3 days (yes I know that was being sarcastic). I can foot brake it on the street to ~1800-2000 and I'm assuming I could go just a little higher at the track meaning I won't be out of boost for long.
This of course is just what-if statements. I just wanted to get an idea of what kind of power I'd need to hit 11s, not what gear I should run. I think I got my answer so I thank you guys for the help. When spring comes around and the tracks open again I will be sure to update you guys.
To late douche bag. You came off rude. Build your car the way you f%&King want and quit starting threads like this if you dont like what anyone has to say!!! Dudes like you never follow thru anyway. Here you are talking about 10s but your thread is asking for about advice getting into the 11s. Do you even understand the difference in power & set-up between a 11 and a 10 second car? Here you are talking about what you have read and completely disregarding what someone who has owned turbo cars tries to tell you. You cant even figure out how much HP you need to run 11s without posting a thread on a forum!!!
