Whats it gonna run ?
The heads were assembled by AFR, I'd imagine they're decent springs as the heads are nice. rod bolts are the good ARP press in ones, oil pump is a OE replacement type IIRC.
For tire I'm guessing a 26" would be right for me ? Was going to get some welds, run skinnies up front and not decided on slicks or DR's yet. Not sure if DR's would hook off the line with the 5 speed. But I have seen wheelstands off the Mickey DR's
I've always been anti nitrous, I know it's fairly cheap and effective. But I've always hated on it because if the bottle runs out you don't have ****. At least with turbo/blower you also have that kick in the ***. I'd catch so much **** if I ran n02 right now lol.
Eh, interior has everything minus a radio and a headliner. the 79 seats are pretty light compared to some of the newer stuff, not much to them lol. Don't even tilt.
nitrous is just throwing a bandaid on your problem, the camshaft. By the time you're done setting up a reliable nitrous setup and filling bottles you could have just bought a good hydraulic roller cam and get what you really want out of it.
I'm with the the other guys and saying the cam will hold you back big time from what the motor could make IMO slicks before dr's (blew my center section on dr's) go on and tear the interior out if what you mainly want is a track car and sharpin up those shift quite a bit bit do a 5-6k launch and enjoy the ride!!! With that said I could see 12.3's and for more weight ditch the front n rear bumper supports. Probably close to 50-60 pounds
I don't get it...
Stock cam and 3160 race weight with 290hp.... Do you think I don't have more than mid 12's??
Hmmm, this has me thinking. I really want to see 11's. I'm not spraying it. I do need a water pump, this would be when I'd toss a new cam in. PTV clearance worries me a little as I know the E-cam clears. Then I assume I'd have to remeasure and have some new pushrods made again correct ?
I don't get it...
I don't get it...
