Hangwire's KB 2V, Tune/gear/exhaust LS1
#22
Yeah i'm not sure what the deal is with my air leak issues. I have personally gone through all the hoses/fittings myself checking for leaks. I have had multiple shops check for leaks. Nobody has found anything. The symptoms are as follows: Computer dumps all fuel it can @ idle, once I get to driving it starts pulling the fuel back but still adds some. Once my car is up to temp and I shut it off it will run LEAN as hell once I start it back up(open loop). It literally runs like 18 A/F and you can hear the exhaust stumbling like hell, it sounds just like a mild cam. Get this....as soon as I put it in drive and drive around the block and get it on closed loop it will idle fine. 14.5-15.5 A/F and no stumbling. Air has gotta be coming in somewhere. I get lean codes on the drivers side every few months and thats it. Spraying water/soap mixture below the blower around the intake is pretty much impossible - there is no room to get up under there with the intercooler and all.
I have replaced: PCV Valve, IAC Valve, MAF, Driver's side o2 sensor. Exhaust checked out ok with no leaks.
I re-used the intake manifold gaskets that came with my KB kit when I bought it used. According to the seller they had ~2K miles on them. Seller was reliable and from this site so I do believe that. I think it was a bad idea though and I'll bet that gasket is leaking.
Anywayyyys yes I ran slower but I still think I improved. Stone has put on LTs, SLP lid modification and 3.73s since we last ran together and I think he ran almost the same times E/T. So it was just a lil slower day.
First time we went was in October of last year. I ran as follows...
1st Run
Reaction: 1.4
60 FT: 2.30
1/4TH: 12.92
MPH: 112.44
2nd Run
Reaction: 1.11
60 FT: 2.24
1/4th: 13.01
MPH: 110.73
Today I ran....
1st Run
Reaction: 1.30
60 FT: 2.24
1/4th: 13.46
MPH: 109.78
2nd Run
Reaction: 0.97
60 FT: 2.21
1/4th: 13.64(OUCH)
MPH: 108.23
3rd Run
Reaction: 0.73
60 FT: 2.20
1/4th: 13.32
MPH: 109.22
I improved on all three runs today so i'm really not upset at all. I'm getting the hang of it. On that last run I pretty much released brakes fully on the second yellow light and just punched gas and it felt much much better off the line. On all my other runs I was starting as I released the brakes and I think with all this torque thats not really helping me. I need to break 2.2 60 FTs and figure out if this air leak is hurting me or not.
I attached my dyno sheet. The only thing that I have done since then is MAC O/R H pipe.
Edit: 3.73s and/or Megabite JR LCAs are coming soon. Also considering FLSFCs but want to prevent adding more weight for now.
1st Run
Reaction: 1.4
60 FT: 2.30
1/4TH: 12.92
MPH: 112.44
2nd Run
Reaction: 1.11
60 FT: 2.24
1/4th: 13.01
MPH: 110.73
Today I ran....
1st Run
Reaction: 1.30
60 FT: 2.24
1/4th: 13.46
MPH: 109.78
2nd Run
Reaction: 0.97
60 FT: 2.21
1/4th: 13.64(OUCH)
MPH: 108.23
3rd Run
Reaction: 0.73
60 FT: 2.20
1/4th: 13.32
MPH: 109.22
#25
Last time me and Hangwire were out there, I was running high 12s (12.7-12.9) at 108-109. Next time with really good air I dropped it down to 12.5 to 12.6 at 110-111. Then after the LTs, gear, and lid mod it ran 12.2-12.3 at 114 and 113. Yesterday kind of sucked for everyone. Seems like all the cars I've seen out there before were down 2 mph. A brand new SRT Chally with pretty good driver mod only trapped 108.
