The Racers Bench Is the track just too much for you? Want to know what will beat what? Talk about it here!!
Slick experT question
Old 10-01-2012, 10:01 AM
mighted1987
mighted1987's Avatar
Default Slick experT question
I got a deal going on some 15" hoosier
28.0 -10.5-15 going for 100$. 50% used, does tht still stick ? http://montreal.kijiji.ca/c-ViewAdLa...AdId=416651283. Link to image
Also what is the offset needed to clear rear break on a 15" rims? I just
Want a pair for the last 2-3 drags ill be doing
mighted1987 is offline
Old 10-01-2012, 07:45 PM
mighted1987
just realised they are 10.5, no ****ing way ill find a fitting rims except thoses 800$ worthy...and that prolly require a sway bar relocation and more. dang and that must be pretty ruff on the car having such huge slick, prolly for 600+ hp setup
Old 10-01-2012, 08:34 PM
ctgreddy
ctgreddy's Avatar
my car has a 28x10" slick on it with no issues. imo a 10.5" slick is similar in size to a 275/285 tire, not as big as it sounds. get some 15" v6 mustang wheels and go racing!
ctgreddy is offline
Old 10-01-2012, 10:55 PM
Stone629
Stone629's Avatar
Greddy, wouldn't a 26" tire suit you a little better as far as gearing goes? Or are you able to break traction pretty easy with the 28s?
Stone629 is offline
Old 10-01-2012, 11:07 PM
Diabolical!
Diabolical!'s Avatar
If they have at least 50% tread, they'll still hook. I don't see any pics of the wear indicators, so you have to go off of the seller's word that they are 50%. A 28x10.5 slick fits best on a 15x8 rim. A 15x10 is too wide for that tire in my opinion, so relocating the sway bar is not.a concern. I actually run a Hoosier QTP slick (27x11.5x15) and Hoosier recommended I run that size on a 15x8 rim as well. To clear the rims, buy a pair of racestar 15x8s with a 5.5" backspace and they will clear every part of your car, even the stock sway bar. Don't buy the racestar lugs. They are junk. Buy some McGard lugs instead.
Diabolical! is offline
Old 10-01-2012, 11:10 PM
Diabolical!
I'd imagine with the 4.10s and M90, a 28" slick won't be too much tire for him. If it is, pulley down!
Old 10-02-2012, 05:40 AM
mighted1987
I need special lugs nuts? Btw a rims shop told me to lass by and they will couple of 15" rims to see which would fit. Would i need the hoosier with it for the test or if i get a rims working n fiting along that mean it will fit with the hoosier? Asking cuz im planning to try rims and if something work id go buy the slick.
Old 10-02-2012, 06:05 AM
ctgreddy
ctgreddy's Avatar
yeah i think 26's would work better for me just couldn't pass up the deal i got on my 28's.
ctgreddy is offline
Old 10-02-2012, 04:26 PM
Diabolical!
Most drag rims use a different style lug nut than stock. Race stars use a shank style lug with a washer. If you're using a different offset/backspacing than is common for S197s, you may need to mount the hoosiers to be sure they clear the fender lip and bump stop bracket. If you know the width and backspacing of the rims you plan to use, I can tell you if the tire will clear, but if it's not a brand of rim commonly used on S197s, then you'll still have to mount the rim to be sure it clears the brakes, etc.
Dokilar
15
10-16-2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
Quick Reply: Slick experT question
