Testing waters WTT 86GT LOTS of MODS
1986 GT T-TOP 5 SPD 176,XXX on car 34,XXX on motor and tranny New tires
The GOOD
GT-40 Cast Iron Crate Motor--Have reciept
B 303 Cam
Cobra Intake
FMS 65mm Throttle body
FMS MASS Air Conversion ($500)
FMS 24 lb injectors
Granatelli 75mm MAF
190 LPH Fuel Pump
Vortech FMU
Flow Tech exhaust/Mufflers
2.5 Inch piping
FlowTech unequal length headers
Pace Setter H-Pipe with NO Cats (Have reciept for H-pipe)
Paxton SN2000 Supercharger (pretty fresh)
Griffin 3 core radiator
Air Conditioning WORKS (Freeze 12)
New Spark Plugs (.034 Gap)
Body
Needs Paint/very small ding on left fender top side/ small surface rust
T-tops-someone tried to break in and tore up the weather stripping on drivers side (still have key for Ttop)
Overall very solid car
Interior
window tint needs replacing
Driver seat had a tear, I stitched it up by hand
Has mats with cobra embroided in it
Carpet is old- I have new carpet that has been sitting in the garage for a while
Original radio
Replaced driver side window motor (both windows work great)
Dual pillar pod with boost and a/f ratio gauges
center console with water temp and oil pressure gauges
Air only blows out of defrost (small vacuum leak)
Nothing really too wrong with the car besides the cover plate that goes to the transmission has only 2 bolts holding it and makes a noise when the clutch jumps and whatever was mentioned above
Extra parts
Extra set of FMS 24lb injectors (need caps)
19lb injectors
Stock MAF sensor
Extra 10.5 & 10 in clutch and pressure plate
Extra Gt-40 Crate flywheel
Stock airbox and silencer with AmsOil air filter
This car has always had AmsOil run in it until this previous oil change
Various other little parts
Runs like a champ-Does not burn/use any oil or water. Very strong, even with stock gears.
PM me with your trades offers
Cut and paste to your browser
http://i154.photobucket.com/albums/s...yofdbz1474.jpg
http://i154.photobucket.com/albums/s...n1/dbz1532.jpg
http://i154.photobucket.com/albums/s...n1/dbz1522.jpg
http://i154.photobucket.com/albums/s...n1/dbz1512.jpg
http://i154.photobucket.com/albums/s...n1/dbz1502.jpg
http://i154.photobucket.com/albums/s...n1/dbz1492.jpg
The GOOD
B 303 Cam
Cobra Intake
FMS 24 lb injectors
Granatelli 75mm MAF
190 LPH Fuel Pump
Vortech FMU
2.5 Inch piping
Body
Interior
Original radio
Extra parts
19lb injectors
Stock MAF sensor
RE: Testing waters WTT 86GT LOTS of MODS
Any offers....I also have a 1995 Hyundai accent I can trade.
A newer GT or Z28 with good paint and body. Must run good. But I will consider all trades. If need be, I can combine my GT and my beater (95 Accent, runs good with A/C)
I'll even take another Fox with a good paint job that runs good.
Anyone have a 94-95 GT/Cobra for trade. I have more pics if needed.
hey man if i were you...with the interior being ok and the paint not so hot..i would take that thing to macco let um paint it cheap just get it looking ok and sell it for twice as much as your asking...with the supercharger it will bring pretty good money. just a thought..if i had some extra cash id be all over it..but jsut had to fix the tranny in the old girl so i cant swing it..jsut a thought tho.
Thanks for the tip. I may just pull it off the trade list soon and just flat out keep it. It runs real good, but if I do keep it, I am gonna put an awesome paint job on it. Actually I think that I will keep it now.
09-01-2015 08:16 PM
