Tuner Central Have a question about which hand tuner is best for your Mustang? Talk about it here!
Hypertech
Old 11-25-2010, 09:41 PM
muellergt2007
muellergt2007's Avatar
Default Hypertech
My tuner (42004) has a cooling fan setting so that I can set it to come on at 180 or 195 but before I jack with it do I need a special thermostat to start with? If I don't need a special stat how do I know which degree is the right one and will a 180 or 195 setting really do anything for the performance side of things?
muellergt2007 is offline
Old 12-01-2010, 04:14 PM
Hypertech Support
Hypertech Support's Avatar
Default Hypertech Max Energy Programmer
The setting for the fans is set up according to which thermostat you are using in the car. The factory thermostat is a 195 degree and you will set it on that setting & it will bring on your fans a lower temperature, low speed on at 209 and off at 200 degrees, high speed on at 219 and off at 210 degrees.
If you have a 180 thermostat the low speed on at 194 and off at 184, high speed on at 204 and off at 194 degrees.
Thanks Gary @ Hypertech
Hypertech Support is offline
Old 12-02-2010, 09:28 AM
Hypertech Support
You do not have to have the cooler temperature thermostat. You can bring fans on sooner with the cooler stat. For this application you can run either thermostat. If in a cooler climate you may want to run the factory 195 thermostat. If in a hot climate it will help you run a little cooler & maybe a couple of horsepower.
wildazme
06-12-2005 06:07 PM
todds03
04-23-2005 02:16 PM
normanbaites
22
03-12-2005 09:42 PM
302mustang
01-30-2005 02:25 PM
mackjr80
11-10-2004 10:57 AM
Quick Reply: Hypertech
