Noob needs help with diablo predator
07, v6 auto. i bought the diablo predator and i keep reading about specific options in the tuner for a k&n intake, which i have, but i have gone through (seemingly) every menu and have not been able to find anything specific. the instructions dont get too specific so im having alot of trouble utilizing it to the max. can anyone point me preferably step by step where to access this setting from the tuner?
im getting an exhaust put on and also lsd and new rear gears, so at this point should i just have a pro create a custom tune for all my mods?
i have seen a few people mention that there was a specific option to change for a k&n intake(as well as several other popular aftermarket intake kits) under the options you can modify; i have not seen this option. i dont want to tamper with the options for fuel and air myself and screw something up, so i was hoping to find where i can select that. am i wrong, is there no option for that?
Oh, I misread when you said you had that, you meant the actual CAI
If you dont see specific CAI tunes, you likely need to update the Predator to the latest revision, as it sounds like its pretty old.
Thanks
Thanks
hmm, i had ordered it not even a month ago, and even updated it to the 9r07 revision(although i think it was already on that software version), but i guess im just not looking in the correct spot. ill play around with it when i get home
