Questions using SCT SF3/X3 ??
Hi, Everyone.
When you connect an SCT tuner for the first time it uploads the stock file. Now is that stock file stored for good in the tuner or does it upload it every time the tuner is connected?
A little backgorund. I have a 2005 Gt Auto. Last night I connected the SCT X3/SF3 for the first time and while uploading the stock tune I recieved the following warning messages;
check trac control
check charging sytem
fule level odo data err
When it completed I ran the 91R tune from BAMA. Followed the included instructions and proceeded to install my JLT series 3. Finished up and started up. Idled and died a couple times. It was getting late and I had to be somewhere so I swapped on the stock intake and connected the tuner to return to stock. While programing the tune the same warning messages appeared. When the tuner completed the messages went away but my gas gauge moved erraditically to the full position. From what I can tell it is runs fine althoug I did not drive it.
I proabably installed the intake incorrectly and will try again today after work. I am doing my research to get some ideas from the forums on whether these messages are typical or if it has ever happened to anyone. Please chime in and let me know what you think.
check trac control
Make sure there are no leaks with the CAI. As for the warning messages, I never had anything like that happen. You had the car on "On #1" and not actually have the car running? Did you purchase the tuner brand new?
Im concerned about the warning messages while the tune is uploading or programing and really concernend about the gas gauge acting crazy.
I am contacting SCT to see what they think.
Ok so I reinstalled, everything tight and good to go, also programed the tune that came with my tuner combo. While uploading the stock tune and downloading the 91r tune I still got the error messages on the dash. They went away when the tune was complete and loaded. Still have the crazy gas gauge on the dash.
So the MAF sensor was installed correctly, all clamps were tight, and hoses connected. With the tune the car starts, the RPMs jump to 1500 then calm down to about 750 and just sputters until it dies which is about 8-10 seconds. Maybe my tune isnt correct. I have the Bama tunes and Im pretty sure I filled it out the online form correctly...hopefully. Im gonna order another tune. Im gonna call SCT anyways first thing in the morning to see whats up with the gas gauge on the dash.
Right after I load a new tune in it asks to turn off the key, then I turn the key to the position just before start because otherwise it cranks over for 3-4 seconds. If I let it sit in that mode for that first start for a few seconds (I guess to build fuel pressure) it will fire right up, rpms go to 1500 and settle down. You could try going into the adjustment options and setting your idles to 790 or so and see if that helps. I checked mine and they are set to 740, no problems.
I have an 06 GT with the same with tuner you have, I also get those messages when the in the programming phase. I figured it was normal and I haven't had any problems with anything sticking (like the gas gauge).
And I hope SCT can figure out the gas gauge issue. Thanks so far to everyone who has read and responded.
Its Alive!!!
No need anymore. I loaded my new tune and installed my JLT3 and it runs and drives good. Definitely takes some getting used to. Pedal is really touchy now.
My gas level gauge is still wacky. I filled up the tank and now my needle is at 4 o' clock. If I can figure how to upload a pic, ill post it. I sent SCT my stock file and hopefully they can figure it out tomorrow.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
