Can an sct tuner turn of tpms of a new 13???
I was wondering can the sct tuner turn off the tpms for the new 13s or is it not capable of doing that!!! reason asking is instead of spending 200 for new tpms i could spend another 170 and get the sct with bama tunes and turn off the tpms then, i was just wondering!!??
SKTER97,
Unfortunately the SCT can't turn off the TPMS. However with 11+ the TPMS sensors are valve stem mounted, so you can reuse them if you don't plan on keeping them in the stock wheels. That would be a pretty awesome feature if it could though!
I hope this helps!
- Dan
SKTER97,
I hope this helps!
- Dan
I hope this helps!
- Dan
SKTER97,
I hope this helps!
- Dan
I hope this helps!
- Dan
Yes sir you can just demount them from your factory wheels & throw them in your aftermarket wheels, that's the beauty of valve stem mounted TPMS !
Where ever you get your tires mounted will be able to pop them off your factory wheels for you with out any problems!
Hit me up if you need any assistance with your order!
- Dan
ernesto-619
09-10-2015 01:32 AM
