Do I need a tune? - MustangForums.com
Tuner Central Have a question about which hand tuner is best for your Mustang? Talk about it here!
Sponsored by:
Sponsored by:
Old 07-31-2014, 09:27 AM   #1
leftyatm
Default Do I need a tune?
Hey guys eventually I am going to build a mild 302. Stock bottom end with forged pistons. Probably a trick flow head and intake set up with a mild cam. Obviously I'll do exhaust offroad h pipe and flowmasters. I plan to keep it fuel injected, 65mm throttle body. It is currently speed density. So when I upgrade, I know that I will have to switch over to mass air. As far as a tune or custom chip, do I need anything like that? Will I be able to build this, get it timed and need any special air/fuel ratios? I don't plan to put out a ton of power. I plan maybe 300-350. I want it to be reliable and a weekend cruiser. Is this possible? Will the mass air sensor adjust this set up accordingly?
leftyatm is offline   Reply With Quote
Old 07-31-2014, 10:01 AM   #2
Mike@DiabloSport
Premium Sponsor
Mike@DiabloSport's Avatar
I've built and dealt with more aggressive 5.0s that never had any tuning done to them, and they ran well. Having an adjustable FPR and a distributor makes things a little simpler.
Best bet is to get it all together, and see how it runs and drives.
If it has idle issues, cruise issues, etc, then you should consider having a chip burned for it.
Good luck.
Mike@DiabloSport is offline   Reply With Quote
Old 08-02-2014, 03:10 AM   #3
leftyatm
Thanks!
Old 08-11-2014, 11:30 PM   #4
N8187
N8187's Avatar
Default Depends
Speed density mass air
N8187 is offline   Reply With Quote
Old 08-11-2014, 11:31 PM   #5
N8187
N8187's Avatar
Quote:
Which one,
Old 08-13-2014, 08:28 AM   #6
64bit
64bit's Avatar
Quote:
The foxbody computers are very adaptable to modifications made to the car... However, you will not reap the real benefits of your engine build, without a tune.
64bit is offline   Reply With Quote
Old 08-14-2014, 11:09 PM   #7
yourmom6990
Get a tune for maximum gains!
yourmom6990 is offline   Reply With Quote
Ethanol Free Fuel Tune Sixx 2005-2014 Mustangs 9 10-05-2015 08:36 PM
Any tuner available 95 3.8 ?? patchshaffer Tuner Central 3 10-05-2015 03:24 PM
Street Action Tonight Explosive Street/Strip 17 10-02-2015 08:45 AM
So who wins uedlose The Racers Bench 4 10-01-2015 09:31 PM
Reminder - Steeda Pony Wars October 17th tj@steeda Florida Regional Chapter 0 09-30-2015 09:04 PM
