Will not stay running
Old 11-14-2011, 10:00 PM
wendylynn
wendylynn's Avatar
Default Will not stay running
Help!! I just replaced a blown head gasket in a 1999 mustang v6 3.8. Now it will start but dies and goes poof. I made sure the plugs are right and can't seem to find any missing connection. Stumped and really need the car to be running soon. If anyone can give give me some ideas without taking it back apart and starting over,I would really appreciate it.
wendylynn is offline
Old 11-15-2011, 01:23 AM
petrock
petrock's Avatar
How long does it stay running for? Security system with a fuel cut-off? Battery gets the car started, but the alternator keeps it running. If it is properly connected, try taking it to a local auto parts store and have them test your alternator. Good luck...
petrock is offline
Old 11-15-2011, 09:59 AM
wendylynn
wendylynn's Avatar
About half a minute..Don't think it has a security system with fuel cut off. (Hope not) Alternator is about a week old, just put it on before the head gasket blew.
Old 11-15-2011, 05:56 PM
du907
du907's Avatar
I'm thinking intake manifold not on correctly so you have intake leak that causes the "poof".
du907 is offline
Old 11-19-2011, 07:26 AM
wendylynn
wendylynn's Avatar
Somehow I got it to quit with the "poof" noise and then realized it sounded like it wasn't getting enough gas..Did not know that you have to "bleed" the injector line. It had air in it. Car is running now, hopefully for a long time, it already has 191,000 on it.
Old 11-19-2011, 10:31 AM
WoahPony
WoahPony's Avatar
i was gonna say check for air in the fuel rail but you got it! turn the key to on a couple times, but do not start the engine. Then release pressure fron the shraeder valve on the front drivers side of the fuel rail to bleed any air bubbles. Wear gloves though and wash your hands immediately. You don't want to almost have to go to the hospital for fuel poisoning like someone I know
WoahPony is offline
11-18-2015 01:34 PM
MusicCity615
09-12-2015 07:05 AM
uedlose
09-10-2015 03:30 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Quick Reply: Will not stay running
