Oversteer or Understeer
Old 12-20-2006, 01:56 AM
eaglecatcher
eaglecatcher's Avatar
Default Oversteer or Understeer
Do mustangs naturally have more of an oversteer, or understeer? I've heard they have pretty bad understeer, but mine can be very tail happy, especially in wet weather. I have no mods, so I'm wondering if they have more under/oversteer?
eaglecatcher is offline
Old 12-20-2006, 02:04 AM
jthorn9
The Godfather
jthorn9's Avatar
Default RE: Oversteer or Understeer
Depends, comming out of hard turns they have bad oversteer, well V8s anyways, but naturally they're more understeered than over, going into a series of hard turns at a decent speed, they deffinitly have understeer, just depends on the road/driving conditions.
jthorn9 is offline
Old 12-20-2006, 02:06 AM
eaglecatcher
oh, because my tail kicks out extremely easy in wet
Old 12-20-2006, 02:08 AM
jthorn9
The Godfather
jthorn9's Avatar
"SARCASM" Well, see how easily it kicks out when comming into a 60+ degree turn at 70+ MPH, you're unless you drift that car into the turn, you're gonna find the car very hard to steer.
jthorn9 is offline
Old 12-20-2006, 02:50 AM
cobra232
cobra232's Avatar
stangs as well as most oher rwd's exhibit oversteer far more than understeer like fwd's
understeer occurs when you run 245's up front and 275's out back. also known as plowing, the fronts don't have enough meat to keep up with the rear.
run 245's or 275's on all four corners and you will be more likely to oversteer 9 times out of 10 unless it's wet and even then oversteer is more common
cobra232 is offline
dubarado
12-23-2015 01:16 PM
09-08-2015 11:50 AM
ccwebb
08-11-2015 06:47 PM
oxfordgt
30
12-04-2008 04:06 PM
Mustangansta
11-14-2006 11:21 PM
Quick Reply: Oversteer or Understeer
